Question about Ovens
Amana model: arg7301ww mfg: p1143330nww The broiler turns on by itself when a burner on the stovetop is turned on. Called a repair person who said it's probably the thermostat. Does this sound right? Any other ideas on what could cause this to happen and how to correct it? I don't use the oven at all and if there's any simple way to permanently disconnect the oven that would be a reasonable solution.
  • manugambhir Oct 04, 2009
    Rylee,
    Can you tell me which numbered item on the schematics is the control board and which is the power board? I am inexperienced with ovens but want to locate these and try to disconnect the wires for bake & broil elements from the control board and from the power board.
    Thank you.
    Manu
    Rylee,
    There is no part #27 or #28 on Schematic 1, Image 2. I also want to reconfirm the bake igniter part #s quoted below are correct - they seem to be part of the body?
    Thanks,
    Manu
    President:
  • 1,714 Answers
Is this a 'gas' oven ?
Posted on Oct 04, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This is happening due to a shorted connection on the control board or due to shorted wiring for broil and burner connections. Please make sure that there are no shorted connections on the control board. Also make sure that the wires are not loose or burnt. This is not due to the thermostat.
If you have expertise in repairing appliances or have previously disassembled these kind of appliances then I'll suggest you to check the control board and the wiring to the broil and burner. And, to disconnect the bake/broil function you can simply disconnect the wires for bake & broil elements from the control board and from the power board; after disconnecting remember to insulate them with electrical tape(don't leave them loose).
Please see these schematics, these will help you disassemble the oven(Click on them to zoom in)---
Schematic 1
amana
model: arg7301ww
mfg: p1143330nww
Schematic 2
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 03, 2009
  • Rylee Smith
    Rylee Smith Oct 04, 2009
    Hi
    You’ll need to disconnect Broil Igniter Part # 27 from Part
    # 28 (Schematic 1 Image 2) and Bake Igniter Part # 17 from Part # 18 (Schematic
    1 shown between Image 2 and 3).
    Thanks
    Rylee
Amana oven, AGR5835QDW igniter in oven is shot. Stovetop lights, broiler lights. How do I access the oven igniter to replace it?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven ProblemsReplacing the Igniter
heatman101
Apr 01, 2011 | Amana Ovens
Amana gas oven (model#: ARG7301ww) does not heat. I do not hear the gas turn on or the ignitor go when I turn on the oven. The burners on the range work as usual.
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 07, 2011 | Ovens
My oven is not working The Broiler works and the stove top works fine but the oven will not heat and when you turn it on no gas comes out I tried turning it on and using a lighter but nothing happens
You gave us good clues in information!-- Thanks!
Most modern gas ovens have a device called a Glow Ignitor to light the burner.
If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights:
Do you see a bright glow near the Broiler burner?
(Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like-
But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
I hope this helped.
Mack B
Jan 27, 2011 | GE 30 In Freestanding Gas Range ...
Oven "bake" burner wont ignite on a gas oven.
heatman101
Dec 27, 2010 | Whirlpool Ovens
Jennair gas oven. lower burner won't light, i.e.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 16, 2010 | Jenn-Air JGW8130DD Gas Single Oven
The oven will not light and is throwing a breaker. Is this something fixable? It has been slow to light for a while now, and we usually have to turn on one of the stovetop burners in order to get the oven...
can you access the ignition module,if so try using one of the connections from the module that ignites a stove top burner and see if this line connected to the oven lights the oven now and doesn't throw the breaker,then you would know that section of the module is defective
Feb 11, 2010 | Ovens
Oven won't light. Broiler will ignite and
I don't know how new or what brand your oven is, but chances are you have a bad igniter the bottom burner. It is a small element attached to the burner that should glow red hot when you turn your oven on to ignite the gas. This is the most commment setup and problem. You will have to remove the bottom tray (there are usully 2 finger screws holding it in) to see it. It should look something like this:
http://www.theignitorstore.com/product/306602/range_oven_igniters
If you turn the oven on and nothing happens, turn it back off. You can disconnect the igniter, connect a multimeter set to volts AC, turn back on and check for voltage (120 AC) Don't let any bare wire ends touch the oven or you. If you have power there, its the igniter.
Just get the model number off your oven to look up the proper replacement. Replaces with 2 screws. Make sure it mounts close to the burner. It should only take a couple seconds after you hear the gas turn on to ignite. Hope this helps.
Jan 02, 2010 | Ovens
Smoking Oven
soundsas if you have a dirty stove, Id reccommend running through en extended cleaning cycle, it will SMOKE, that s geting rid of any food/grease trapped inside the flue and cabinet of unit
Jan 31, 2009 | Amana Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
