Question about Humax Televison & Video
Humax LU23-TD2 has a 4 digit password set on menu for programme search. I never set password . How do I reset it to access tuning options.
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
SOURCE: HUMAX TELEVISION LU23/TD2
Same problem Humax LU20/TD2 TV; Virgin remote
Posted on Dec 18, 2008
Turk_97
  • 131 Answers
SOURCE: Unable to access digital audio output options
Well you also need to have a digital feed to the television. example: When I run my optical cable from my dvd player to my television directly. I went in to my menu options on my source and enabled this. If you are wanting to run this feed to your a/v amp? You may want to run the original feed from your dvd player to your amplifier directly, you will get a sound quality that is far superior to what you seem to be doing here.
Posted on Sep 24, 2009
  • 458 Answers
SOURCE: I ws using my humax to watch a programme, when the picture froze.
It can sometimes happen if the signal level drops & the TV digital decoder cannot pick up the strength of the signal when the transmission is back to normal. Switching on & off again resets the processing again. This is a similar effect that can happen with cable or sky transmissions also, it acts the smae way as sometimes having to re-boot your PC if that should crash. It is not necessarily a fault with the TV.
Posted on Oct 24, 2009
Testimonial: "Sounds logical, but why did not the TV digital signal also crash? "
SOURCE: I have a Humax LU23-TD2 Flat Screen LCD TV and I
I have the same tv, has started to give out a few seconds of black screen on the odd occasion whilst watching-might b going the same way.. the tv repair bods might b your only solution if u dont know any electrician that could give it a test
Posted on Jul 30, 2011
My receiver humax hd free after upgrade i want to back to old soft ware how to return back to old version
There is a setting in the tuning menu to tune HD channels.
Installation/Manual Search - select Transmission DVB-T2
Aug 20, 2015 | Humax Televison & Video
How do i unlock Humax LU23-TD2 TV
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Visit the associated blogsites too.
Sep 21, 2014 | Humax Televison & Video
Setup humax lu23 td2
have you tried plugging other any other components to the ports to see if it does the same thing
Dec 01, 2013 | Televison & Video
Humax lu23 td2 cannot retune it say menu not avaliable when i press the menu button
Is tv being used in the av modes if so tuning menu will not show. Possible cause could be external units like dvd player are taking control . Unplug all external unit and try menu again
Regards Derrick
May 13, 2012 | Televison & Video
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
My Humax Duovisio PVR-9200T often freezes completely and has to be switched off at mains for a few seconds. Or commands from remote (eg subtitles, menu, channel change) take minutes to respond. Or...
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
May 03, 2010 | Humax DRT400 DVD Recorder w/ 40 hr Tivo
My PVR has retuned (DSO)to the wrong transmitter. I receive signals from the Winter Hill transmitter and live in SW Cumbria. My Humax 9200T has retuned ok but my older 8000T has retuned to a transmitter in...
Not a complete solution but after much fruitless fiddling through the menu I eventually found that the programmes were actually there but under different channel numbers.
I searched a long way down the LIST of channels (on remote) The BBC1 channel I want is now 800 BBC. Selecting 1 on the remote still brings up BBC Wales.
This applies to my Humax 8000T PVR - I can't comment on other makes of Freeview box.
Nov 05, 2009 | Televison & Video
Oct 24, 2009 | Humax Televison & Video
Apr 13, 2008 | Televison & Video
Televison & Video Logo
208 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
