Question about Philips SPC 900NC Webcam
Sound feedback using the camera as audio device with Dell Inspiron 9300, very bad feed back making camera and audio unusable. Have adjusted volumes, speakers positioning ie laptop stereo. Nothing seems to work any suggestions Thank you
    Sergeant:
  • 226 Answers
Are those add-on speakers, not clear on that? Feedback is almost always a problem involving speakers and microphone being to close together or mic being to hightly modulated. It is possible that power lines being to close could induce a hum of varying severity.
Posted on Feb 22, 2008
How do I switch off the microphone to stop the speakers feeding back on my laptop. And how to set the levels when I am recording, to stop feedback.
I think it won't be possible to get rid of the feedback and quality will be poor when recording this way. Try software like Audacity and set the audio source to record directly from the sound card. The input device should be set to "Windows WASAPI" for Windows and output set to a loopback device.
How to Record the Sound Coming From Your PC Even Without Stereo Mix
Feb 11, 2016 | Dell Inspiron 15 5000 Series Laptop...
MY DELL INSPIRON N5040 INTERNAL SPEAKER IS NOT FUNCTIONING BUT I CAN HEAR THROUGH HEAD PHONES
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope it helps
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 14, 2012 | Dell Inspiron 1525 Laptop
Just prchased a Logitech Z-640 6 Speaker Surround Sound System. I have a dell inspiron one computer and the sound system has the green, orange and black cable. How can I get the system to work with the...
the drivers might not be installed or you might not have selected the right speakers
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 21, 2011 | Computers & Internet
The sound from my Dell Inspiron has some scratchy moments and some incidence of slowing, then resuming correct speed. I believe it is a bad sound card. I have never installed a sound card and I don't...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Feb 17, 2011 | Dell Computers & Internet
Lost sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 06, 2010 | Dell Inspiron 6000 Notebook
No sound devices on my dell inspiron 5160
Hello...
Full details about sound issue in my website...
www.sureshayyar.110mb.com (Support page)
As an alternative u can do this (i am using this solution till date)
If u cant install the sound driver correctly, just buy a " USB Sound Adaptor" and connect it to the USB port and connect the speaker sound jack to the sound port in this adaptor....u will get back the sound....also keep in mind that u " may " have to disable onboard sound in BIOS, u may also have to make changes in the Control Panel / Sound and Audio Devices / Audio Tab / Sound Playback option... Click the drop down button and select the "USB Audio Devices/Headset"
You can get it in Ebay for $1 to $4 or google it to locate a place near u......
This is the one i am refering to(I bought it in Ebay for 1$)....u can buy something similar also....there are many available mfd from China, just plug and play on your USB port....
If you find this solution useful please leave a feedback and rating to this solution.
Regards....
All the best, my dear friend..
Mar 16, 2010 | Dell Inspiron 5160 Notebook
My battery will not recharge and the volume does not work
Battery:
Portable batteries are consumable and have a expected lifespan of roughly 300 to 500 recharge/discharge cycles before replacement is required. If you are using the original battery, then most likely you need a new one. If battery is a new replacement and you have the same issue, flash the BIOS to most current, see if any change. If not change, and a new battery doesn't charge, then replace the motherboard.
Volume:
You were not clear if this is a NO SOUND or just VOLUME IS LOW issue. For NO SOUND
  1. Open Volume Control, Ensure that sound is not muted.
  2. Control Panel, Sound and Volume controls. Ensure that the sound card is selected as the primary playback device.
  3. BIOS, ensure the Audio is Enabled.
  4. Download and reinstall the audio driver.
If you are just talking about the volume control displaying on screen, reinstall the quickset utility
Nov 15, 2009 | Dell Inspiron 9300 Notebook
No audio output device
You need to reinstall the drivers. Get these from support.dell.com
Mar 28, 2009 | Dell Inspiron 6000 Notebook
Audio device
you need an audio driver... visit this web and download audio driver...http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Dell-Inspiron-1000-Audio-Driver.shtml
Jan 09, 2009 | Dell Inspiron 1000 Notebook
Philips SPC 900NC Webcam Logo
190 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
