Question about Samsung RS2630SH Side by Side Refrigerator
Front panel getting hot - Samsung RS2630SH Side by Side Refrigerator
    President:
  • 1,304 Answers
With samsung this could be normal, or it could be an idication you need to clean out the back vent
Posted on Oct 03, 2009
Overheating of Partition in a side-by-side
pull off the bottom front kick panel and check the condenser coil to see if it's filled with dust,also pull out the machine and remove the back bottom panel and make sure the condenser fan motor is running and clean out any dust back there,if the coil is clogged with dust or the condenser fan motor isn't working is what could make that strip hot.
Aug 30, 2012 | Whirlpool Refrigerators
Samsung DV338aew does not get hot
I just took the front panel off of my Samsung dryer the belt is off. If you take the front panel off you won't believe what you will see it's so much dust... from all the clothes drying. Did you tried to take the front panel off? First turn off the switch to the dryer at the fuse box so there will be no power in there while you vacuum it out. As soon as I can put the belt on I will vacuum it thoroughly. I'm sure that is the reason why it the temp... is not hot enough.
Good luck.
Erika
Aug 12, 2012 | Samsung DV218AEW Electric Dryer
The front panel between the refrig and freezer doors is getting too hot to touch Would tht be a defrost timer or thermostat?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Jun 09, 2011 | Refrigerators
Very hot to touch between fridge and freezer on front panel
on front panel around the door where the door seal goes up against is this what is hot check the compressor fan in the back of the machine when it doesnt run or is unoperational then the sides around the door get hot you might have to replace the compressor fan
Aug 12, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Mould in water inlet assembly how to remove this assembly for cleaning. the fabric softner try never gets drained. Has a three valve inlet sysrem.
Pull the dispenser drawer out until it stops then push down the release tab and pull the drawer out completely. Separate the parts then immerse it in hot water with bleach and give it good a scrub with an old toothbrush.
The dispenser drawer cavity does not need to be removed for cleaning. Otherwise, you have to remove the top panel, console, toe panel, and the front panel. Removal of the front panel requires the removal of the door lock/switch assembly and the boot be separated completely from the front panel opening. Use hot water to loosen the mold then spray it with household cleaner with bleach. Let it sit for a couple minutes before starting to scrub the molds off.
Jul 03, 2010 | Kenmore Elite 45986 Front Load Washer
How do you take the bottom front panel off? The dryer motor works, but it doesn't get hot (just warm). I thought if I took the front panel off I could clean it and maybe that would solve the problem.
It doesn't get hot since one of a series heater element is burnt out. It needs to replace the heater element. You have to access it from the back panel of the unit. To change the heater element, you don't need to take the bottom front off. Good luck.
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Built in oven front panel gets too hot
No. There should be a fan that runs and blows cool air from a gap at the top of the door and over the controls.
Feb 15, 2010 | Ovens
Back of frigidaire dryer very hot , can I get the back off to see what makes it so hot
that's normal there is a big round heating coil connected to the back of the dryer,you have to get in the dryer in the front,unscrew the top and the front panel-mike
Apr 20, 2009 | Dryers
The dryer does not stay hot
You probably have a restriction in the exhaust somewhere. Check vent to outside , if that is okay remove hose from back of the machine and look for lint buildup in hose and machine. More than likely the problem is in the duct in the front panel where the lint screen goes. To check and clean this you will have to remove the front panel.
Apr 04, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
Panel between fridge and freezer hot on Kenmore fridge
It is normal for that panel to get warm while the fridge is running. There is a hot gas tube from the compressor running through it to prevent frost built up. If it's feeling a little too hot try cleaning the coils under the fridge. This will allow the gasses to cool a little more efficiently thus allowing the fridge to cool quicker.
Nov 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Samsung RS2630SH Side by Side Refrigerator Logo
129 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
