Question about Sony KP-57WS500 57" Rear Projection Television
I am having shades of colors with picture and color of shadow
jbreth
  • 69 Answers
SOURCE: PINK/GREEN SHADOWS, LINES
Here is what I was able to find out about your problem from sony: This issue is usually caused by some type of nearby magnetic interference, such as unshielded stereo speakers placed too close to the TV. These spots can be small or large and will normally be red, green or blue, but sometimes appear purple or pink. They normally occur on the sides or corners of the screen, but can also appear in the middle. To resolve this issue, move any stereo speakers or other electronic devices away from the TV; a minimum of 2-3 feet is recommended. If the situation is not remedied immediately, unplug the power cord of the TV from the electrical outlet for 20-30 minutes; repeat this process one more time if the issue is not resolved the first time. If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer in your area. Hope this is helpful:)
Posted on Sep 04, 2007
  • 1694 Answers
SOURCE: colors not matched
Yes,there are convergence alignment adjustments, to be adjusted
by a technician after set is repaired.Replace STK392-560 IC's,then
check alignment..........T.
Posted on Oct 30, 2007
Ecollier2012
  • 3459 Answers
SOURCE: Double pictures
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on May 22, 2009
  • 81 Answers
SOURCE: color are not lined up color shadows are not
coverrgence ics are bad
Posted on Apr 22, 2010
hardrocko
  • 1476 Answers
SOURCE: Our 7 year old
a ladha,
You have lost the convergence circuitry. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will explain the problem, tell you where to get parts and explain how to do the repair.
Thanks for using FixYa and for the great rating!!
hardrocko
Posted on Sep 12, 2010
Certain colors show up as green instead of their intended color. Usually, occurs in shadows or reflective surfaces.
Game cartridge save battery needs to be replaced is a hassle but can be done, First split the cart case open find out what sort of battery purchase and replace. Some N64 Cartridges required the battery to be soldered in and out.
Jan 11, 2013 | Nintendo 64 Console
Picture has ghost shadows in the faces of people mainly news anchors. Light colors like whites and oranges also have shadows. What could be causing this?
If it does not really display this when a DVD etc is played via a rear audio/video input it is not the set.
Modern cable or sat signals often are compressed and sets cannot on close up views keep up with the signal--when signal is compressed it causes this kind of issue--no way around it.
Jun 16, 2012 | HP Pavilion MD5020N 50" DLP HDTV
My Mitsubishi 1080HD model WS-55315 colors are not correct. The blue is good and the green seems to be, everything else seems to be a shade of light brown or tan. I thought maybe the red tube was bad but...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines like R,G,B mis alignments,also tv have any colors shaded shadows pictures or a 3D pictures look alike?Yes,than the tv have a convergence board problems and it is dead to causes all of these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops repair a DLP tv convergence board will cost u like $300-$350 for parts an labors.
Sep 12, 2011 | Mitsubishi WS-55315 55" Rear Projection...
I have aquires a Magnavox rear projection tv. The picture is sharp but is in shades of red and pink. Obviously the green and blue are not working correctly. Any Ideas besides kicking it to the curb?
The tv have a problems known as a convergence pictures problems,the tv convergence board it is dead,that why tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv can be repair,by fixing the convergence board,by replacing 2 STK convergence ICS and some or all of it resistors too.Will fix convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors,to save this tv.
Jul 27, 2011 | Philips Magnavox 51MP392H Rear Projection...
Red is ghosting to the right. i replaced the convergence tubes about 6 months ago. went with the expensive ones "not the cheapy's" used heat sync putty stuff and everything. the problem is...
Yes,the tv problems it is the same,it is the tv convergence problems again,now it just color it is shaded in shadows pictures,instead of wavies mis colors R,G,B mis alignments.Yes.The tv convergence board it is the problems,must be repair again.
Apr 27, 2011 | Sony KP-57WS500 57" Rear Projection...
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
Ghost shadows in multi colors
u need to replece the convergence ic , this are 2 big black piaces # stk392-110 or stk392-150
Apr 12, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Mitsubishi WD-52631 shadows and blurs in dark lit movies
If you are getting the same problem with both TV monitors it could then be assumed it's an input problem to the TV monitor. If you are using a digital output from your receiver it could be the cabling. If you are using an analog output from your receiver it is probably coming from the receiver.
Digital video processing does have issues with darker scenes.
Can you try another video source seperate from the receiver like a DVD or better yet an analog VHS, if you still have one. Good luck and let me know.
Sep 17, 2008 | Samsung HL-R6168W 61" HDTV
Good Day;
You may have a lamp going bad,when was the last time you replaced it? Or the DMD or light engine, try lamp first. Good Luck, big IRISH.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Sony KP-57WS500 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
