Question about Epson Stylus Color 580 InkJet Printer
How do I change a bad black ink cartridge when the computer blank ink level is still reading half full?
  • 624 Answers
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Posted on Jan 20, 2007
  • 749 Answers
SOURCE: Cannot print in black only
It is not wise to leave the cartridges empty, causes permanent print-head damage on the empty color area. However, if you want to use the other color, say "black", bypassing the cartridge check is simply resetting the counter of the printer... download the utility file "sscserve.exe" you can search it on the internet. Install it then choose your printer on its list box, then by right-clicking on the printer icon of the utility at the bottom right of your window... you should be able to see what you need. Happy printing!!!
Posted on Oct 28, 2007
SOURCE: blank pages
Even though I changed my black and colored ink cartridges twice, the printer still prints blank pages. What should I do?
Posted on Dec 27, 2007
mediatecar
  • 60 Answers
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Posted on Feb 15, 2008
SOURCE: after replacing the black ink nothing prints
Hello, I am having the same problem and have done extensive research to find out that with this exact problem you have mentioned, you must clean the printer head, nozzles, and waste ink tube. the process is a bit long and needs patience. You will have to take the print head assembly out of the sliding caddle and put it in a glass of rubbing alcohol to disolve the dryed ink within the printer head assembly. it is held in with a silver metal plate that runs across the assembly and screws to the sliding carriage. be carefull to remove the black clip on the right of the carriage to take it out. note to be careful to not pull the white info lines of the head. leave it in the glass overnight and also clean the tube that runs under the waste pad station and clean the clear waste tube as well. ....Good luck
Posted on Apr 08, 2008
Color ink level shows half full, however prints only black and white parts
According to your problem, first make sure that the cartridges are not blank. Take the cartridges out and try to feel that it is not blank by shaking the cartridges. If it is OK then clean the head of the cartridges and align them again. It will help you.
Jun 21, 2011 | Canon Pixma MP480 All-In-One InkJet...
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Does not print, printer head moves across the print but only black pages i only get blank pages. all the ink cartridges are full
Has the printer sat for a while without printing? Are you using a refill kit or new cartridges?
An ink cartridge will dry-up if it sits for two long. When this happens the computer will read that they are full, but in reality they are bad.
If you are using a refill kit to refill them then they are likely clogged (common problem with refilling). You can try cleaning the cartridges where they meet the paper, with a cotton swab and some rubbing alcohol.
Most likely the cartridges need replaced.
Oct 23, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Esp 5 -prints with blue tint-black level reads half-color reads quater full
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.Printhead is the part which holds the cartridges and has 4000 nozzles which sucks ink from cartridges.It Might have gone bad.
Sep 26, 2009 | Kodak ESP 5 Printer
Orange blinking light at cartridge icon
The Amber light is designated as the "Ink Error" light. With regards to a 960C Hewlett Packard or almost any inkjet printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
Sep 10, 2009 | HP DeskJet 960c InkJet Printer
Printer cartridge is a refill and does not seem to be recognized
Maybe you can try to reset the black ink level 1st. To reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Dec 23, 2008 | Lexmark X2500 All-In-One Printer
Neither black or color will print..
remove and check cartidges it is quite possible that the cartridges must hve dried up.
Dec 08, 2008 | HP PhotoSmart C4180 All-in-One Color...
My printer now only prints blank pages.
try wiping the contacts (gold colored spots) with a tissue, and after wipe the ink despensing end.
Dec 03, 2008 | Lexmark Z600 InkJet Printer
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus Color 580 InkJet Printer Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
