Problem with netgear wgr614 v6 daisy chain
Trying to daisy chain Netgear wgr614 v6 off of Verizon Fios Actiontec router. My computer detects the wireless router but I can not connect to the internet
  • Anonymous Mar 17, 2014
    Actiontec router internet light red
  • 556 Answers
I am assuming the Verison was setup and working before this started, if not let me know.
Do you know the address and subnet mask for the lan side of the Verison Actiontec router? assumed like address 192.168.0.1 subnet mask 255.255.255.0 This means all addresses 192.168.0.? belong to the verison router's subnet.
Assuming the Netgear router is being daisy chained using a lan port from the Verison Router to the WAN port of the Netgear, the WAN side of the Netgear router needs to be either dynamically addressed or statically addressed in the 192.168.0.? uniquely outside the DHCP range for the Verison router.
The LAN side of the Netgear Router must not be addressed the same as the LAN side of the Verison router in this configuration.
There is another potential configuration where lan ports of both routers are connected. however in that configuration there are additional considerations. Please let ne know which connection you are attempting between the two routers.
There is some additional informatin you can gather
Assuning you have windows XP for the operating system on your computers hook a computer wired if possible to the LAN side of each router and issue the following commands
Click Start then All Programs then Accessories then Command Prompt in the new window that opens type the following command and press enter
ipconfig
write down th IP Address, Subnet Mask and Default Gateway for each adapter
Then issue the following command once for each default gateway not = 0.0.0.0 where {...} is replaced in its entirety with the default gateway.
pring {default gateway address no {}}
the expected responses will be either 4 timeouts or 4 lines with elapsed times. Timeout is failure -- elapsed times means it was connected.
For each router I need to know the default gateway and the subnet mask for the successful pair. Plese reply ina comment to this problem and additional steps will be forthcomming.
Posted on Dec 21, 2007
How do i access wireless internet on a dell dimension 4500s computer to a actiontec m1000 router
To RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Oct 03, 2012 | NetGear WGR614 Wireless Router
I am trying to change the cfe on my netgear wgr614 V6 tdc but the jtag doesn't see it. The ends I am trying to get to is putting dd-wrt on it. Any ideas?
I don't know TDC version of v6, if you still have it please provide info about components (processor, flash, RAM). I have some with processor BCM5352, flash 29LV800 (some with 29LV160), RAM Samsung K4S641632
Mar 14, 2011 | NetGear WGR614 Wireless Router
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Trying to set up a netgear access point with a moterola surfboard
Try doing a hard reset on the Netgear router then powercycle it together with the modem
Mar 07, 2010 | NetGear WGR614 Wireless Router
Trying to connect netgear wgr614v9 router to new toshiba computer with windows 7 ....setup says unsupported operating system....what do I do
As netgear setup disc doesnot support Win 7.
U need to manually setup the netgear product
-- hard resett the router using a restore factory setting hole on the back of the router
-- open the netgear router page using www.routerlogin.com
-- Username - admin , Password - password
-- run setup wizard
-- if it detects dynamic ip then press next
-- and on the left u will see wireless settings under setup .
-- secure the network using WPA_PSK(TKIP)
-- and then apply .
In case if it will detect static or fixed ip .
Then click on " Basic settings "
-- Under router MAC address
-- select "use computers MAC adress "
-- Apply
-- And then Powercycle the network..
-- And u will be able to go online ..
Jan 02, 2010 | NetGear WGR614 Wireless Router
Lost instruction
Lost instruction - NetGear
Nov 05, 2009 | NetGear WGR614 Wireless Router
Verizon modem/router and Netgear WGR614v9 On Demand setup
  • the modem and router must connected
  • either you use a long ethernet cable to connect the tv to the router or use a powerline to extend the router.
Jul 31, 2009 | Actiontec (GT704WG) Router
Netgear wgr614 v6 As Bridge for XBOX
I'll take a stab at this. It's a bit difficult because I don't know what your level of expertise is. You're actually using the Netgear wireless ROUTER not a bridge. Your ISP can use a couple of methods to give you service. DSL companies like Verizon probably use PPPoE which require you to login and provide a password and VZ is notorious for closing down port 25.
O.K. Did I mention I don't like them very much? Anyway, I'm going to give you a link to Netgear's excellent web site for configuring a router and the XBOX connection. This is the whole list of v6 compatible instructions. Note the very bottom link to use Netgear routers with XBOX.
http://kbserver.netgear.com/products/wgr614v6.asp
Note under the Troubleshooting topic that there is a configuration and two setup files, depending on what you're connecting to, and some tips on what to do if it doesn't work.
It's not as bad as it looks.
Carl
Jan 04, 2009 | NetGear WGR614 Router
Wireless router PPPoE login info
PPPoE login n password is from your Internet Service Provider that you sign up with.
Jul 15, 2008 | NetGear WGR614 Wireless Router
New computer lost install disk!
Hello, Here is a link for the firmware and drivers for your router. Hope this helps.
Mar 23, 2008 | NetGear WGR614 Router
Computers & Internet Logo
712 people viewed this question
Alun Cox
David Payne
David Payne
