Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi ws65809 error code 23
My mitsubishi 65 inch tv shuts off a few seconds after turning it on.
The error code I get is 23 stands for "horizontal deflection failure.
I figure it is a problem in the mainboard section and possibley a resistor and maybe leakage to ground.
Can you tell me where to look or what parts to order.
Do I need to replace the whole board?
Thanks,
Yalmer
    President:
  • 4,402 Answers
Ok there is alot of things that need to be check with this code
check first:
CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB . Before replacing the fly, as I have not had any of these flys go bad, Check all of the capacitors and diodes on the sweep power supply. This is the voltages the flyback makes for the rest of the set. also check pin 10 of IC%A)) for voltage. If there is voltage, the HV protect is on. Check for a shorted or leaky D5A60 in that same circuit. i found this 15 volt zener to be bad a couple of times.
STK393-110. The IC needs to be replaced and also you must check the small fuses in the main power supply that are marked F9A04 and F9A05
also check for
The "oil" is the coolant (ethylene glycol) that has seeped from its containment to the internals of your display. While not a common occurance, it does happen.
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
Posted on Dec 21, 2007
  • Cary Farah
    Cary Farah Dec 21, 2007
    additional i would replacve all 1000uf caps from 16volts no matter what
    Scholar:
  • 152 Answers
I would recomend you to send it to some repairman, but still i can tell you it must be a transistor..and its better for him to fix it
Mitsubishi tv ws-65809 shuts down after a few seconds, get a code 23. I was reading a post you said that only needed to soder something?
2,3 is a deflection circuit failure; These sets rarely have soldering problems there or elsewhere.
I would suggest either it is a shorted part in that area (High Voltage and sweep circuits) or it is possible it could be a Glycol issue.
A deflection circuit problem would require a schematic (widely available on internet for free) and a meter to check for voltages and or for shorts.
Glycol can be inspected for visually and if seen care must be taken.
Let me know if you have questions.
Last suggestion would be if you have not done it, unplug set (this clears the error buffer) and plug back and turn set on, if it fails double check the error code again.
Steve J.
Nov 04, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Will Not Turn On
First you need to do a self test diagnosis and then if it comes up with:
SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Do self test by pressing Input/Device and Menu at the same time for 5 sec. the set will show a 2 digit seq. first blinks followed by a short pause then the second.
Dec 29, 2007 | Mitsubishi WS-65807 65" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I have a mitsubishi model ws65809 big screen tv. When I turn power on it only stays on for 10 seconds then shuts off. I checked the fuse but fuse was fine.I want to know if I changed the lamp will it fix...
You will need to press the menu button and the input buttons on the TV both in together for five secoinds then count the two digit blink code from the power indicator. the blink sequence will repeat several times. let me know the sequence of the blinks.
May 30, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My 65 inch projection TV turns off within a few seconds when I turn it on. Why? No pictures or sound.
If power light does come on and a few seconds later it goes off---do the self check that the WS65909 MITSUBISHI should have:
On the front of the set press and hold both the MENU and INPUT(OR DEVICE) BOTH FOR 5 SECONDS AND THEN RELEASE BOTH BUTTONS.
Power light should blink a two digit code--error code---for example: 2 blinks, a pause and 2 blinks.
Let me know what code you get----it will repeat it several times---and I will tell you what it means.
SD TECH
Nov 03, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Turns of after being watched for several hours.
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Oct 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
May 01, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Yes my nickname is cztop i have a mitsubishi big screen tv & need guns ajusted
try unplugging tv for 30 minutes remove all speaker away from tv and anything magnetic after 30 mins turn back on try that
Aug 23, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Ws65809 projection tv
You can purchase parts online at these two links
http://electronix.com/ or http://www.matelectronics.com/
Either one should be able to help you out. If they dont stock your part check back with me and let me know exactly what your looking for and i will post a link for you. Hope this helps.
Jan 05, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
229 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
