Question about Hotpoint Ultima WF860 Front Load Washer
The washing machine wont drain out , but will
The washing machine wont drain out , but will drain with gravity, has the pump gone?
    Genius:
  • Hotpoint Master
  • 1,466 Answers
Could be , you could remove pump and put two wires onto to check but be carefull Electricity kills..Could also be feed to pump from machine,Check 1st nothing is sticking blades , which is most likley
Posted on Oct 03, 2009
How to drain water from my lg WFT75A31EP washing machine after washing the clothes?
If the drain pump is faulty and you are unable to pump the water out of the tub, simply take the drain hose and lower it into a container to catch the water which will be drawn out by gravity.
If this fails, check the drain hose for foreign materials clogging it.
Nov 16, 2015 | LG Washing Machines
Washing Machine cannot drain & spin after the wash.
ok pull the machine out and lower the outlet pipe in to a bowl and see if the water will drain under gravity if it does it could as simple as the pump jammed drain the machine remove the pump and clear jam, if it wont drain it could be blocked see if your machine has a filter (will tell you in handbook) be careful you can get very wet! I always lean them back about 30degrees to send water to back of drum
Mar 03, 2014 | Daewoo Washing Machines
Xqb90 701clps
check for a clogged pump. follow the drain line connections to locate it. spin and rinse will not happen until after a majority of the soapy water has been removed
Nov 20, 2013 | Washing Machines
My Westinghouse LT 9555 washing machine won't spin how to fix problem??????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 06, 2010 | Westinghouse Washing Machines
Washing machine wont drain
Hello,Do you hear the pump running when it is supposed to? If no and the machine is still under warranty, take advantage. If you do hear the pump running, but nothing comes out--lower the drain hose down near the floor to see if it will gravity drain into a bucket or pan. If it drains, then the pump isn't moving anything even though it is turning--it must be replaced. If it doesn't drain freely, then something is blocking the drain--a pinched hose either to or from the pump, or maybe a stray sock blocking the outlet from the outer tub.
Thanks
May 19, 2010 | Tecnik TKL9260 Front Load Washer
My lg washing machine is a semi automatic model 6.2 kg . water is not getting drained don't know why?
Sounds like a pump or drain hose blockage.. Check filter. Could also be the pump motor. The more resent synchronous pump motors get detritus inside them and gradually 'gunk up'. You may be able to drain the machine by lowering the drain hose and allowing gravity to help. this won't work if the drain hose is mounted high at rear of machine......Nomess
Apr 09, 2010 | LG Washing Machines
My washing machine wont drain water
Do you hear the pump running when it is supposed to? If no and the machine is still under warranty, take advantage. If you do hear the pump running, but nothing comes out--lower the drain hose down near the floor to see if it will gravity drain into a bucket or pan. If it drains, then the pump isn't moving anything even though it is turning--it must be replaced. If it doesn't drain freely, then something is blocking the drain--a pinched hose either to or from the pump, or maybe a stray sock blocking the outlet from the outer tub. The last item usually isn't considered a warranty problem. Hope this helps!
Mar 28, 2010 | Tecnik TKL9260 Front Load Washer
Wont spin to get water out of the cloths
Check the operation of the drain pump and the rest of the drain system. Lay the drain hose out near the floor (put the end in a pan or bucket) to see if it will gravity drain). It must drain to get to the spin cycle. Hope this helps!
Feb 21, 2010 | Kenmore Elite 20972
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Our maytag neptune mah8700aww front loader will not drain and unlock the door. what do i do.
The drain pump os obviously either blocked or gone. Lie the drain hose on the ground to drain by gravity. Then have a look at the pump. This may need to be taken out as I'm not sure if there is a pump filter on this particular model. The door is designed to not open with water in the drum.
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
