Question about Ovens
Wont get over 175 degrees - Ovens
    President:
  • 1,304 Answers
If this unit is gas,
its your ignitor
its not getting hot enough to open the safety valve
Posted on Oct 03, 2009
How do I remove the sabbath function on my gas range
sadly without knowing a make , there is not much I can look for.
has to be something to do with the clock I would suspect
Oct 23, 2016 | Ovens
Gas Pizza Oven - Heat issues
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Mar 05, 2014 | Ovens
The lowest setting on the dial of our Imperial oven is 175 degrees F. If we set the dial below the 175 mark, could we get the oven to level out at a lower temperature? We're looking to achieve a stable...
The temperature figures on the dial are a guide only. Play with the dial, you will pick up where the thermostat cuts in and out. 130 deg. is rather low, but it could be achievable. You will only find out through experimentation - nothing will be damaged.
Jan 31, 2011 | Imperial ICV-1 Turbo-Flow Single Oven
Oven only goes to 175 degrees
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 30, 2010 | Frigidaire GLEB27S7A Electric Single Oven
If my grandmothers cookbook says to bake something at 175 Celcius, what is that in farenhite?
175 degrees Celsius is equal to 347 degrees on the Fahrenheit scale.
The conversion formula is
Fahrenheit temperature = (9/5 x Celsius temperature)+ 32
http://www.trueknowledge.com/q/what_is_175_degrees_celsius_in_fahrenheit
Good Luck
Nov 22, 2010 | Ovens
How best to cook turkey. What setting?
hi friend,
step 1
Preheat oven to 325 degrees F.
  • Step 2 Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
  • Step 3 Rinse turkey inside and out with cold water. Pat dry with paper towels.
  • Step 4 Put oven rack on lowest level of oven.
  • Step 5 Place turkey, breast side up, on a roasting rack in a roasting pan.
  • Step 6roast1s.jpg Rub the outside of the turkey with olive oil.
  • Step 7roast2s.jpg Salt and pepper the turkey's body and cavity.
  • Step 8roast3s.jpg Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
    • In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
    • Be sure to check out other eHow turkey recipes - search the site for "turkey."
    Who Can Help Sponsored
    • How to Lose 30+lbs Guaranteed. Try it Free.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Viking Ovens
    My jenn-air self-cleaning electronic wall oven model w131 is heating up very slowly. It took 1.5 hours to get to 175 degrees.
    One of the 2 hot wires is out. Flip (hard) the oven circuit breaker to the off position, and then back on. If it did not help - verify 220-240v between the two hot wires on the terminal block behind the electronic control. If there is less - call electrician.
    Oct 13, 2009 | Ovens
    Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
    Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
    Sep 18, 2007 | Ovens
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
