Question about Ovens
Both boiler and bake elements are dead. Electric Timers still work. What parts are the likely cause?
Thanks for your help. I did press the "solution accepted" button.
I doubt that I am going to persue fixing the oven. It is old (16 years) and the parts seem to be outrageously expensive. Your tech did point that out to me say the parts would be hard to find. I found them but they are too expensive.
It is part of a double oven so we will use the bottom half for now.
Thanks, Bruce
Posted on Oct 05, 2009
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Think i blown a fuse/ where do i find the fuse
First check to see if power is coming from outlet, with meter or check breaker in panel box of main. Then you will need to be careful and check inside of oven power supply inside unit
Dec 22, 2007 | Whirlpool RBS305PDS Electric Single Oven
Tip
Broiling and baking element in my electric oven are not heating.
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in series on the circuit from electroning oven control to elements. The probe will control both baking and broiling element, opening the circuit when limit temperature is reached.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
on Mar 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
My 4 top elements work but my oven doesn't.
Take the back cover off the range. Locate the bake element terminals near the bottom of the oven. Turn bake on and check for voltage. If no voltage then replace control board. If voltage is good, then unplug oven and check for continuity. If no continuity then replace bake element. Also, does broil element work or is it dead as well? If both oven elements are dead then the control board is most likely at fault.
Aug 10, 2009 | Frigidaire FEB27S5A Electric Single Oven
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn Air W241 bake element not working
Most ovens are relatively simple; an element and a switch/thermostat. Usually it's one or the other that goes bad. If you have a good Volt/Ohm meter you can test the parts saving you un-needed expense.
A Volt/Ohm meter will pay for itself in parts and safety.
A service manual with circuit diagram will go a long way in saving you time and money. Most service manuals are available online for free as a PDF file.
Happy baking. Photo is a pizza baked at 300 o F with Pizzacraft brand pizzeria flour purchased online.
Dec 15, 2017 | Ovens
Ovens Logo
16 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
