Question about Sony Handycam CCD-TRV68 Camcorder
No Power in Sony Handycam DCR-TV265E
There is no power in my Sony Handycam. Its not charging up. Tape is not coming out. Its totally dead, even when plugged to mains. Handycam was not in use for the last 3 months. Please help.
silly girl
  • 513 Answers
SOURCE: Sony Handycam DCR-PC1E
I'm not from the UK so can't help you find a lab. but regarding your problem - The fact that it works well without a tape tells us that the load motor and possibly even the capstan motor and associated mechanisms are working. It doesn't tell us much about anything else though. Could be that the head drum is not spinning - This can be the result of a siezed drum motor, or power supply fault(if seized it will draw excess current, thus giving a battery warning indication). A faulty, or possibly even a correcly working dew sensor - This will allow the heads to spin, but prevent the tape from actually lacing up. This is a 'hard' one really, because if the dew sensor is faulty you will get this problem, but you will get the same problem when the sensor is working and actually doing its job in that it has really detected moisture. There are many other possible causes too. The first thing to look for is to see if the heads are spinning - or at least see if they *try* to spin, because unless they *are* spinning the tape will never load. Also, the heads *shouldn't* be spinning with no tape inserted - if they are then this suggests that the dew sensor has been activated (the heads are made to spin under this condition in an attempt to dry things out). If this gives no clues, the next step would probably be to dismantle the thing and attempt to load a tape by hand (looking for signs of jamming mechanism, etc. Anything more serious than this is one for the workshop. Platano guatemalteco? Good luck!
Posted on May 29, 2006
SOURCE: Sony DCR TRV33 Handycam Driver
i have lost my driver for my Sony DCR TRV33 Handycam Driver. Can you help?
Thanks
Posted on Jan 17, 2009
welcomejee
  • 10594 Answers
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Posted on Feb 26, 2009
megarza
  • 88 Answers
SOURCE: Driver of Sony Handycam DCR-TRV285e
you can download the drivers here http://support.sony-europe.com/dime/camcorders/d8/d8.aspx?site=odw_en_GB&m=DCR-TRV285E
Posted on Aug 20, 2009
  • 85 Answers
SOURCE: My Sony Handycam DCR-HC26 started giving me
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
Posted on Mar 20, 2010
Sony dcr-pc9 ejects tape when trying to load....not a claening issue..common symptom on this model
Try this:
1. Turn off the Handycam
2. Remove the battery from the Handycam.
3. Remove the AC Power Adapter from the Handycam.
4. Move the Handycam power switch to the ON position.
Note: Leave the switch in the ON position for at least 15 seconds.
5. Move the Handycam power switch to the OFF position.
6. Connect the AC Power Adapter to the Handycam.
7. Turn on the Handycam.
Apr 05, 2011 | Sony Handycam DCR-PC9 Mini Digital...
My Sony Handycam DCR-PC9E mini DV Digital Camcorder is totally dead. Even powered the camcorder at Camera position and reset it according the operating manual. Yet there is no response at all . Is there...
This is a simple case of the Bat going dead, it does look from what I read that the Sony batteries do not seem to stand up long these days, I am hearing of this daily on the Mini Cameras, where my old faithful 8mm camera bat is 8 years old and as good as new.
Jun 13, 2010 | Sony Handycam DCR-PC9E Mini DV Digital...
My Sony Handycam DCR-HC30E mini DV is not working
In many cases I found DC Jack defective in this model and resulted does not charge battery through ac charger nor power up directly with ac charger.
I would suggest to check ac charger and battery on similar model Sony camcorder and I think your camcorder has DC jack problem thats why camera is not getting power from ac charger.
Jan 08, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
Tape compartment will not close
This happened to my sony DCR-IP7E, I had to have this repaired by a camera shop of £129.00 with 12months gtee, work like a new one
Dec 30, 2008 | Sony Handycam DCR-IP7E Micro Digital...
MY SONY DCR-TRV350 won't Power up
push the reset button. i had the same problem and was about to return the camera but then i remembered, you cant return items on the black market. so i pushe reset button.
Dec 03, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam DCR-DVD92
hi dear
please, check your adapter first,
ok
Mar 23, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
Dropped handycam
i think if your handycam warranty still is there then its better to exchange it other wise check the battery still you are having problem you have to take it for repairing
Jan 30, 2008 | Sony Handycam DCR-DVD100 DVD Camcorder
Sony Handycam CCD-TRV68 Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
