Question about Sharp R-1851A 850 Watts Convection / Microwave Oven
The unit works fine, but the plastic frame around the control pad is broken, just above the door open button. Where can I get a replacement part, and how do you get that frame off of there?
    Sergeant:
  • 197 Answers
You must take it to a approved Sharp engineers, who will give you aprice for replacement.
This is due to m/waves holding charge inside even when you have unplugged it and may give a electric shock unless you know what you are doing
Posted on Oct 03, 2009
I have a Panasonic Microwave Model NN-SD277. How do you access the workings of the door opener button? It is broken so the door won't open.
You have to remove the outer cover, the plastic lift levers are behind the door open button / lever. Caution!, panasonic discontinued a lot of those and getting a replacement part can be hard at times. Dont waste your time trying to glue it. After watching people try to glue or epoxy those cheap plastic parts for so many years. I have to warn folks to not waste your time trying. .It will not hold!!!! Look online and try to find a replacement part somewhere. It will be one of two parts. the door open button you push, or the door open lever that the front button pushes against. If you unplug the unit and remove the outer cover simply look behind the front control panel and when you push the button to open the door you will see where it is supposed to lift to open the door. The broke part is your problem, may be a piece laying in the bottom.
Aug 14, 2017 | Panasonic Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 27, 2013 | Microwave Ovens
Door wont open
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2aSkJuabC
Jul 29, 2013 | Haier Microwave Ovens
I have a Panasonic Model #NN-S255 microwave oven. The button you push to open the door does not open the door. It's like there is no resistance when you push the button therefore it does not push up...
Hello,To get the door open and salvage your dinner, take a long thin blade ( I used a frosting spreader) and insert from the bottom between the door and the oven frame on the side with the latches (usually next to the control panel). You may have to pry the bottom of the door open just a bit. The object is to push up the lower door latch (which is connected to the upper door latch) and manually open the door. You may have to try a few times but this worked perfectly for me and saved dinner. Obviously the door latch needs to be repaired but this solves the immediate problem of dinner being held hostage by a recalcitrant microwave.
wish you good luck,
take care.
Aug 02, 2011 | Panasonic NN-S255 Microwave Oven
Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 19, 2008 | Microwave Ovens
Panasonic microwave door is stuck. The door is not opening
If you push in on the open door button and it just goes in and does not open the door, then the problem is that the plastic piece that actually opens the door has broken. You can verify this by removing the cover from the microwave and look inside. If you are handy just buy the part from the panasonic parts store in your city and replace it. If not take it in and they will replace it for you.
Good luck
Tom
Jun 12, 2008 | Panasonic Microwave Ovens
Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 18, 2008 | Sharp R-1480 Microwave Oven
Over the range microwave
Sounds like you have a shorted triac device inside the microwave. Very common problem. This is not a replaceable item for the user to replace.Looking at the age and the make of this microwave,it way be time to purchace a new oven ? Good Luck
Aug 08, 2006 | Sharp R-1460 Microwave Oven
Sharp R-1851A 850 Watts Convection / Microwave Oven Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
