Question about Soyo DYLM1798 Monitor
Signal out of range
I have a Soyo Topaz S monitor. It seems to work fine unless I let the computer sit for a while. After some time the monitor will go black and display a "signal out of range" message. Once this happens I can't do anything to get the monitor to work unless I shut off the computer and reboot. Any idea what can be causing this and how to fix?
  • 1 more comment
  • Anonymous Feb 23, 2008
    My monitor doesn't display a message, but it just turns black and it takes a few minutes of turning it off and on to get it to come on.
  • Razor78 Apr 02, 2008
    Yea I also have the same problem with a Soyo 24". No message but turning black and not coming back on until turned off for a few minutes.
  • John1947 Apr 11, 2008
    I purchased 2 screens. they are great but both turn black with different computers.it is like there is something wrong with the energy saver setting but I can find no reference. I would really like to fix this
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 60 Answers
Hi, these monitors are dropping like flys and it's due to power supply problems. There is a power supply that needs to supply 5v, 12v, 24v. The 5v and 12v is for the logic boards and the 24v is for the back light. On other boards people have tried to repair the supplies with no luck (same here).
The best fix is to purchase two power bricks off of ebay. Get one that supply 5v 12v that are used forexternal hard driveSignal out of range - 2_bing.gif enclosures and get one 24v that is used for mac g4 laptops2_bing.gif. Both can be had for < $10. Then you will have to replace the internal power supply with these. This is not for the beginner, but if you have any experience with soldering and wiring you should be able to do it. You will have to tap into the 12,5 volt wires, I used the PC style power 4 pin connections and attached the other end to the power supply. You will also have to do this for the 24 v lines. A bit of cutting / stripping, soldering and getting the AC to both will do the job.
The only thing that this will not do is shut of the 24 v supply during idle. Best this is to remove power from the monitor when not in use. This should fix an no / power / on then off / problems with this monitor.
Total time is probably about 2 hours and tools needed are the replacement power bricks, cutters, soldering iron, solder, electrical tape, screw driver... etc
ort11
Posted on Jan 17, 2010
Soyo sreen is black cannot sinc with my pc
this can be your computer issue not monitor try connect to other monitor and make sure your computer is working fine ,you can check all the lights on the computer are on and getting no beeps sounds usually you will hear a single beep when PC is booting well
Jul 28, 2016 | Soyo Computers & Internet
Won't power up
Bad power supply board capacitor, most likely.
99.99% probability.
(the other .01% is it is not plugged in)
http://www.ebay.com/itm/Repair-Kit-Soyo-Topaz-DYLM24D6-LCD-Monitor-/330499791194
Sep 03, 2013 | Soyo DYLM24D6 LCD Monitor
Are soyo monitors compatable with dell computers?
try running it in safe mode tap f5 when you see the dell screen. if it boots to safe mode remove the driver for the display adapter in device manager. the dell computer doesn't know what kind of monitor it's plug into. install the soyo monitor driver
Jun 13, 2017 | Computers & Internet
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
I do drawings in Autocad and Photoshop on my 24" soyo topaz s
to adjust the setting on your monitor follow this steps:
right click on the desktop-properties-click Settings Tab-here you find the Screen Resolution then you can adjust it how you want then click Apply and you're done.
Dec 15, 2009 | Soyo MT-NI-DYLM2058 Monitor
It did not display horizontally. part is hiding
try to reinstall the video card driver and see if that works
Oct 10, 2009 | Soyo Computer Inc 19" LCD Monitor, Black
Soyo monitor: Out of Range
Out of range indicates that you have attempted to use a resolution the the monitor is incapable of handling.
Lower your resolution and try again until you can get it to do what you wish then try to do each monitors resolution individually.
Aug 24, 2009 | Soyo Computers & Internet
Color issues: Monitor cannot display proper colors
So are you saying "all of a sudden" as in instantly it happened. Something might of knocked it or it might be broken.
Apr 25, 2009 | Soyo DYLM24D6 LCD Monitor
Soyo DYLM1798 Monitor Logo
331 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Marvin
Marvin
David
David
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
