Question about Jenn-Air JGD8130 Gas Cooktop
Hello. When I turn on a burner, another one
Hello. When I turn on a burner, another one clicks. Sometimes it stops, sometimes it doesn't. Sometimes I have to try several different burners to find one I can cook on without the other one clicking.
    President:
  • 1,304 Answers
They will all click when lighting,
if this is happening after ignition, turn your flame just a bit higher, your loosing flame ground
Posted on Oct 03, 2009
Igniter works, but the clicking doesn't stop
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part http://www.expertappliance.com/partfinder-gas-stove-elite.php
Gene
Aug 11, 2011 | DCS 36 in. CP-364GD Gas Cooktop
The electric igniter sometimes doesn’t stop clicking when the burner is off.
Hi and welcome to FixYa I am Kelly. The igniters are controlled by a switch mounted on the face of the burner control vbalve. The switch operates by rotating a ceramic cam against a movable copper strip of wire to contact a fixed contact. What happens is that sometimes the movable copper wire strip gets bent and stays in contact with the fixed contact. These switches are not repairable and must be replaced when they fail.
I used this model as a reference fopr your part as you provided an incomplete model number in your post. JGP326BEV1BB
The switch is common to all models and can be found as item 323 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214745&diagram_id=20726625#d20726625
Close up view:
http://www.appliancepartspros.com/part_details.aspx?part_id=3191247
There is one switch per burner control. Replacing this switch will correct the problem.
Thanks for choosing FixYa.
Kelly
Sep 29, 2010 | GE 30 in. JGP326 Gas Cooktop
I can't get the electric ignition to stop clicking. I'm not sure this is the right model, but it looked the closest to my cooktop
Hi- most likely the spark module is bad. Sometimes a burner swith gets stuck as well. Unplug the unit, the plug should be inside the cabinet. Take off the knobs and see if you see any obstructions and see if the knob posts move freely in and out (push to turn). Probably need to get a Tech out to look at it. If it is clicking even when the burners are off you can just leave it unplugged and light with a match to use it. If it is only clicking when you have the burners on check to be sure all the burner bases and caps are assembled correctly and seated, sometimes the electrode will continue to click if the burners are assembled wrong or are wet. Hope this helps a little. Good Luck.
Sep 24, 2010 | Maytag MGC7430WS Stainless Steel Gas...
Have trouble starting gas burners on nobel fse90-1. Is there a trick to starting the burners. I need serious help before I go mad!
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | Cooktops
All 4 electrodes spark when only one is turned on
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
Ignitors clicking
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Spark ignitors went on stove top
Jan 09, 2010 | Whirlpool SCS3014LS Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Jenn-Air JGD8130 Gas Cooktop Logo
202 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
