Question about Sewing Machines
The thread gets tangled around the bobbin and the thread knots up on the underside of the material which keeps the material from moving forward.
  • Sewing Machines Master
  • 1,388 Answers
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
The thread gets tangled around the bobbin and - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Martyn
Bargain Box in Australia
Posted on Oct 04, 2009
Ruffler foot bobbin tangles
I suspect that the bobbin thread you are talking about is in fact the top thread that has been pulled under the material, make sure that the top thread is pulled into the tention discs firmly and that there is no fuzz in with the thread, also make sure the top thread is properly threaded and is actually in the take up bar .
Apr 08, 2014 | Singer Inspiration 4206
My Singer 3116 Simple is tangling up by the bobbin and leaving knots of thread on the underside of material?
Thread it right...with the lever up. Then adjust your top tension.
If you still have problems check the bobbin carrier/shuttle for burrs. If you find burrs carefully sand with fine grit sand paper.
Sep 19, 2012 | Singer 3116 Simple
My 6440 Viking keeps knotting up on the underside..it will take a few stitches ..lock up..and when I remove the fabric the upper thread is all tangled up in the throat plate..can you help me..I have t
try changing the needle
rethread the machine top & make sure to use every thread
guide
& make sure the bobbin is inserted correctly into the bobbin
case
clean under the needle plate & in the bobbin area for lint or
threads
make sure the top thread hasn't come off the thread take up
lever
Aug 14, 2012 | Husqvarna Sewing Machines
Bobbin Thread is "birdnesting"
Get out the manual and refer to the maintenance section for cleaning the machine.
Especially the bobbin area. You want to make sure the area around the bobbin case is free of lint and thread.
Use a new bobbin and re-thread the machine, with the presser foot UP.
Install a new needle, again according to the directions in the manual. Installed incorrectly can lead to mis-stitching.
If the problem persits, the timing may need adjusting.
This should be done by the sewing machine tech for Kenmore.
Sewusa.com has a guide for this in the repair section, but you could end up with more problems.
Apr 29, 2010 | Kenmore 15202 Mechanical Sewing Machine
Burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
Jul 16, 2009 | Bernina Bernette 75
Cotton keeps getting knotted from the bobbin
upper tension is wrong or upper threading is wrong (problem is always on the other side of the bunched thread)
Jul 07, 2009 | Janome Sewing Machines
Bobbin gets tangled up
Try taking the covers off again. Now check under and around the bobin case, thats the black plastic bit that holds the bobin. Look for any fuzz or stray bits of thread inside the machine and and around the feed dogs and under the needle too. I use compressed canned air to get in and really blow everything clean. For some reason if the machine is not totally clean, inside the bobin gets tangled up. If you have had even one knot, odds are parts of it are still floating around inside there somewhere and stopping some little lever from moving and jamming your whole machine. Clean under the bobin case too since lint can left it up and keep the bobin from being perfectly level. Also inspect your bobbin case to make sure it isn't scratched along the edge that rotates back and forth. Even a a tiny scratch will cause it jump its tracks and your bobin will lift up and become jamed. In that case you just have to buy a new bobin case. But most of the time your culprit will be some stray bits of thread or lint.
Sep 30, 2008 | Brother SE-270D Computerized Sewing...
Singer 6268, needle timing advice
I have a Singer Sewing machine, Model #6268. The threads have knotted up on the underside of the material. When I finally was able to pull it all out, it caused the needle to hit on the bobbin plate (hope that is right). Now the needle is bending, not going through. How can I adjust it back as it supposed to be? I have had this happen before, but it cost way too much to get it repaired. And I still don't know why this happens (the threads getting tangled).
Thanks!
Mar 29, 2008 | Sewing Machines
Kenmore model 385. 12912890
Make sure your machine is set to feed material. There may be a switch or knob somewhere on your machine to lower the "feed dogs" (the little metal teeth that pull the material through the machine). If they are down, the material won't feed so the machine will sew in place. More likely, since its knotting on the bottom, your machine is probably not threaded correctly. Rethread the machine, and try again.
Yes, the thread on the bottom IS the needle thread.
Nov 25, 2007 | Sewing Machines
Sewing Machines Logo
868 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
