Question about HP DeskJet 6540 InkJet Printer
HP 6540 Lights flashing can't print
HP 6540 In the middle of a print job, red resume button began flashing and I can't print since then.
  • geigermt Oct 03, 2009
    Already tried all of that. Doesn't fix the flasihing light and still can't print
    President:
  • 1,653 Answers
This indicates a paper jam or the printer is out of paper. Do not clear a paper jam from the front of the printer.
The printer might be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of the printer.
There might be a paper jam
1. Press the Resume button. If the paper jam does not clear, then go to the next step.
2. Push the two latch handles on the rear access door toward each other, and then remove the door.
3. Remove any paper that is inside the printer by pulling it out from the back of the printer. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
4. Replace the rear access door.
5. Press the Resume button.
If the Two-Sided Printing Accessory is attached to the printer, follow these steps to clear a paper jam from the Two-Sided Printing Accessory.
1. Turn off the printer.
2. Press the buttons on the left and right sides of the duplexer, and then remove it from the printer.
3. Remove any paper inside the printer.
4. Open the duplexer.
5. Remove any paper from inside the duplexer.
6. Close the duplexer, and then re-attach the duplexer to the printer.
If the Auto Two-Sided Print Accessory with Small Paper Tray is attached to the printer, follow these steps to clear a paper jam
2. Press the buttons on the left and right sides of the accessory, and then remove it from the printer.
3. Remove any paper that is inside the printer.
4. Lift the back lever on the accessory, and then unhook the Small Paper Tray
5. Tilt the Small Paper Tray forward and open the lower door of the accessory.
1. Tilt the Small Paper Tray
2. Open the lower door
6. Remove any paper that is inside the accessory.
7. Close the accessory, and then secure the back lever to close the accessory.
8. Re-attach the accessory to the printer.
Posted on Oct 03, 2009
  • dprochet Dec 01, 2010
    no paper jam
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
Printer trouble
Try following this steps:
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
Hope that helps........
Aug 09, 2008 | Office Equipment & Supplies
I have an HP Deskjet 6540. What do the two orange lights near the on/off switch incicate?
The HP Deskjet 6540 series printer has two print cartridge status lights. The left light corresponds to the left print cartridge, and the right light corresponds to the right print cartridge.
Jan 08, 2011 | HP DeskJet 6540 InkJet Printer
Hp 460 desk top printer will not print and two orange lights are flashing
It would be helpful if you still have the users manual and are able to positively identify the lights.
If the lights that are flashing are the power light and the "resume" light this would indicate you have a paper jam or or the print cartridges are not seated properly.
The resume button is the one that resembles a piece of paper with an arrow pointing down in the middle of it.
Turn off the power, and look to see if there is a piece of paper jammed inside the printer anywhere. Even a small torn piece of paper can cause an error condition.
Remove the print cartridges and turn them around so you can see what resembles a circuit board. Check to make sure the protective cover has been removed from the print cartridges. Once you've done this, install the print cartridges again and turn the power back on to see if the problem has been resolved.
In nearly all cases, flashing lights on a printer indicate a problem with the hardware itself which has nothing to do with the printer driver.
Mar 07, 2010 | Apple HP DeskJet 970cxi InkJet Printer
The light on the right is flashing red.
d40a83b.jpgCancel button
0de392d.jpgPrint cartridge status light
84e6616.jpgResume button and light
e1e1095.jpgPower button and light
- If the power light is flashing it means that your printer may be receiving data.
- If the resume light is flashing you may be out of paper, or you may have a paper jam, you may be printing a two sided document by hand and the first side has finished printing.
- If the print cartridge status light is flashing that means the top cover may be open, of there may be a problem with one of the cartridges.
- If all of the lights are flashing the printer may need to be reset.
Hope this helps.
Jan 06, 2010 | HP DeskJet 932c InkJet Printer
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
Getting error on printer
Take out the cartridges and Perform a partial reset on the printer.
  1. Unplug the power cord from the unit.
  2. Reconnect the power cord into the unit.
  3. When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
  4. When only the On/Resume light is flashing, release the buttons. When the On/Resume light is steady, the reset is complete.
  5. Insert the cartridges and try the print job again to see if this step resolved the issue.
Jul 29, 2009 | HP PSC 1210 All-In-One InkJet Printer
I've had this machine for few years with few problems until just recently. The problem is that the ''check print cartridge'' comes on repeatedly. When I press ON/Resume it either shuts down or the check...
Try the print job again to see if this step resolved the issue.
Hope this helps
Regards
Richard.
Apr 20, 2009 | HP PSC 1350v All-In-One InkJet Printer
Flashing Lights on HP 690C - Won't Print
Hi Stev, First I know this is going to sound strange but have you disconnected the printer cable from the printer itself? (not the computer) If not try unplugging both the parallel and power cables for 30 seconds, then when you reconnect and power up hit the resume button. I've seen problems in the past where a job was killed like that and the printer would not work until the parallel cable was removed from the printer. The light pattern you describe, resume light blinking with the power light on, can mean any one of the following things on that model HP. 1. Top cover is open. Open the top and make sure there is nothing keeping the cover from closing all the way. Don't forget to check the underside of the cover for something stuck to it. Close the top cover. 2. A print cartridge is missing or an incorrect print cartridge is installed. Install the correct print cartridge. AND/OR Verify that the print cartridge is properly snapped into place. Close the top cover. 3. Printer detects an out-of-media condition. Load media in the lower (IN) tray and press the Resume button. 4. Media is improperly loaded. Remove media from the IN tray, re-square the stack, and reload. Make sure that the media-width adjuster and media-length adjuster are against the stack of media. Make sure that media is not buckled in the IN tray. Verify that the media-width adjuster is along the left edge of the tray and is pushing the right edge of the media against the right wall. 5. The printer timed out waiting for a form-feed command. Press the Resume button. The page will eject from the upper (OUT) tray. 6. Printer detects out-of-ink condition. Replace the print cartridge and press the Resume button. 7. Dirty Cartridge Contacts Use a clean foam-rubber swab or lint-free cloth slightly dampened with water. (Distilled water is recommended. Tap water might contain contaminates that could damage the cartridge.) Locate the copper-colored circuitry strip on the back of the cartridge. Clean the copper-colored strip with the dampened swab or cloth. Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. Unplug the power cord from the printer. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp foam-rubber swab or lint-free cloth. Use a dry foam-rubber swab or lint-free cloth to remove the moisture from the contacts. If the carriage contacts show noticeable damage, contact the HP Customer Support Center listed in the printer's User's Guide. Plug the printer back in and try printing again. 8. Printer detects paper in the paper path. Turn the printer off and open the top cover. Make sure that paper is not jammed in the printer. Lift the right black rectangular paper sensor (located in the middle of the printer just below the silver rod on which the cartridge carriage slides) and make sure that nothing is stuck under the paper sensor, perhaps by blowing under the sensor. Close the top cover and turn the printer on. Try printing again. If none of this helps let me know and I'll see what else I can dig up on the problem. El Duderino
Nov 17, 2006 | HP DeskJet 690c InkJet Printer
HP DeskJet 6540 InkJet Printer Logo
499 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
