Question about Microsoft Xbox 360 Console
My sound is coming through, but the picture is not. I'm getting a black screen with small white dots in a grid that will move together slowly across the screen. Other systems work on the tv and will work in the plug in that is used for the xbox. Thanks!
  • 767 Answers
That's a bad sign . Ok you got horizontal line made out of dots scrolling across the screen. and strobeing (flickering) I have seen this only once and it was after I tryed to recover a Microsoft 2 rework box that had 1 red . after re-flowing the G.P.U the unit powered up sounded normal but I got the same thing that you described. So then after re-flowing the G.P.U. again then the C.P.U and H.A.N.A . still the same out come no change . When I check the composite video on my scope the video signal was unstable . it may have been the crystal . I'm not sure , I just put it back together and told the customer that " Microsoft had tryed twice and failed this looks to be a Xxbox" . After consoling him I sold him a replacement and that seemed to cheer him up.
If you find out what was wrong please let me know sorry this was not much of a solution.
Rob
Posted on Oct 03, 2009
My phillips 2006 hd tv has a black line across the screen with a snowy freeze
If you have parallel horizontal black lines on a white background, you can see the separation between the lines when it is viewed at close range (Figure 1). As you view the lines from further and further away,the image gets smaller, you eventually get to the point where you can no longer see the separation between the lines, and it looks like one line. Losing the ability to see separation in the lines is exactly what happens when you sit too far back from an HDTV set. If we apply the same principle to an HDTV, a 1080p resolution HDTV has to fit 1920 vertical and 1080 and horizontal black lines separated by the white space on the screen, (that is the pixel grid of a 1080p HDTV display). Furthermore the spaces between each cell of the grid need to be very small in relation to the area each cell occupies, or you will get a screen door type effect. A bigger HDTV can increase the size of the cells and the separation between the cells, so everything doesn't run together when you sit further back.
Performance chip
May 22, 2012 | Philips Televison & Video
2005 pontiac sunfire rear defrost doesn't work
sounds like a broken grid(the lines across the rear window) or thepower wire has broke off the window
to check this you need some FINE STEEL WOOL
turn the rear defrost on and move the steel wool across the grid not up and down slowly and litely if there is a break in the grid the steel wool will SPARK then mark it keep checking there could be more then one break
then you will need a repair kit
hope this helps
Nov 08, 2009 | 2006 Pontiac Sunfire
My Hitachi 51S500 is showing a black screen
Did you unplug the set from the wall and wait 5 min. replug and try. Cusult your owner manual regarding parental Locks?
Sep 17, 2009 | Hitachi 51S500 51" Rear Projection...
White dots across the screen
It is a timing problem with the cable, you will only get it on 1080p. Is your cable particularly long, or are you using an adaptor (2 x Cat5e network cables)? Try a different cable.
Jan 19, 2009 | Sony BDP-S350 Blu-Ray Player
Xbox
if its less than a year old phone Microsoft customer support.
if not it could be early signs of 3 red lights
Jan 17, 2009 | Microsoft Halo 3 for Xbox 360
Xbox
well then your tv is going out and you need a new tv
Nov 03, 2008 | Microsoft Xbox 360 Console
Have a weird problem M50WH74S RCA
i found out tht it could be the (DMD) Digital_Micromirror_Device i dont know if that is you problem or not
Sep 17, 2008 | RCA HD52W56 52" Rear Projection HDTV
No picture white screen
check you bulb and your color wheel notorious on this set
Nov 20, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung LE32R87B
The fact that this is on all inputs suggests that teh screen is faulty, i would bring it back and get it replaced.
May 09, 2007 | Samsung LN-R409D 40 in. LCD Television
Microsoft Xbox 360 Console Logo
102 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
