Question about Canon imageCLASS D320 Digital Copier
When I feed pages through the automatic feeder, the copies come out with a streak on them. If I put them directly on the glass it doesn't happen. I have cleaned the platen glass with no result.??
    Problem Solver:
  • 16 Answers
You have to clean the small glass that is in the right or left side of platen
Posted on Aug 15, 2013
    Scholar:
  • 40 Answers
It is a cleaning issue. There is a piece of glass about an inch wide that is next to the platen glass or inside the auto document feeder that is probably dirty depending on your model. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Posted on Oct 04, 2009
When using the auto feed, copies come out with black streaks down center of page
If you only get streaks when using the automatic document feeder, then in most cases it is dirt on the scanner glass. You do not state model but if you can also scan flat objects, trying copying a piece of paper that way. If that copy comes out fine, then you definitely have dirty glasss, if that copy has streaks you either have dirt on the scanner itself or a faulty scanner unit.
May 08, 2015 | Office Equipment & Supplies
Streaks on copies when original is fed through Imageclass MF 4694 top feeder; doesn't happen when on flatbed
There is dirt on the ADF glass. Normally to the left of the flat bed glass, there is a thin glass strip. Clean it with a damp cloth.
Aug 06, 2012 | Canon imageCLASS MF4690 Multifunction...
Black line just left of center when using document feeder to copy or scan. This doesn't happen when i put only one copy directly on glass.....
Hi jenni
The problem is in the scanner area. What you need to do is open the ADF (Automatic Document feeder) cover and inspect maybe something is stick to the glass and it appears always. Try to inspect carefully you may see some dirty if you find anything removable like piece of paper do remove it or you can clean it with a dump cloth specially the area where the scanner stops then you use document feeder. This will sure solve your problem.
DO RATE MY SOLUTION
Take care
Jun 28, 2011 | Samsung SCX4623F Laser All-in-One Printer
Regarding copier putting a streak down the paper: I cleaned the rollers, but the streak was still there. However when I put the page on the flatbed instead of rolling it through, there was no streak, so...
If the streak is on the copied paper, then the problem is usually a spot on the glass where the document feeder reads the page. Lift the top cover where the pases feed thru and you should see a thin strip of glass right next to the main large glass. Clean this surface with a soft cloth and class cleaner, don't clean the rollers with the cleaner. I bit you will find you have something on this glass surface that is causing your issue.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 03, 2009 | Office Equipment & Supplies
New toner but still have dark streaks
IF YOU ARE ONLY GETTING THE LINES WHEN YOU PUT THE DOCUMENTS INTO THE TOP FEEDER AND NOT FROM PRINTNG TO COPIER OR IF YOU PUT A COPY ON THE GLASS UNDER THE DOC FEEDER AND NO LINES APEAR CHECK THE SMALL GLASS WINDOW UNDER THE DOC FEEDER THERE MAY BE SOME TIPEX OR INK RUBBED OFF AND LEFT ON THE GLASS THERE.. THISD MIGHT BE CAUSING THE STREAKS YOU CAN CHECK THIS BY PUTTING THE PAGE IN THE DOC FEEDER AND DOING A COPY AND THEN PUT IT ON THE GLASS PLATE UNDER THE LID AND DO A COPY OR IF HOOKED UP TO COMPUTER DO A PRINT JOB.. IN NO STEAK APPEARS YOU CAN BE SURE ITS ON THE THIN SCANNER GLASS.. GOOD LUCK ...a
Jun 24, 2009 | Xerox XC356 Copier
Black streaks on copies. Gestetner 1302 How do I get rid of them
Do the streaks appear when you use the contact glass or just when you use the Automatic feeder?
If both, then you need to replace either the (drum unit) or the fuser roller(s).
If it just happens through the auto feeder, then lift up the "feed-in section" (left side) and clean the narrow scanner glass.
Mar 11, 2009 | Gestetner DSc224 Copier
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
Black streaks are appearing on printed page when scanning
Do the lines only show up if you use the document feeder? If so, there is something on the strip of glass where the page is scanned. Open the top to reveal the large glass area. Then open the part where the paper feeds in when using the document feeder. It will flip open from right to left. There are two pieces to this, so make sure you grasp it as low as possible. You should see a small strip of glass. Clean all the glass with a SOFT cloth. Don't spray any cleaner onto the glass, rather, spray it onto the cloth if you need any.
Apr 19, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printing line on each copy
Most likely there is something on the seal glass, Open the feeder and look at the small strip of glass, see if it is dirty.
the other possibility is that there is a streaking problem in the drum cartridge or in the fuser in that area.
Start with the glass, then look at the drum, You will most likely find the problem on one of those 2 areas.
I really suspect a small spot on the glass where the paper passes over when making the copy through the feeder
Feb 12, 2008 | Office Equipment & Supplies
HP 7410 streaks on scanning and copying
First you need to determine if it's doing from both the  top and the glass.
1-assuming you are using the feeder to fax,copy or scan (the part that automatically picks up the paper) it comes out with a streak. Make a copy putting the paper on the glass and look at the copy. Does it have the streak?
2-lift the top and look to the left there should be a small 1inch glass, this is where it makes the copies from the feeder, is there a dot or white out or is the glass dirty? that's your streak, the paper is moving to make the copy,so the dot now looks like a line as opposed to making a copy on the glass it just sits there so a dot will stay a dot.
2- Clean with water or alcohol.
Oct 23, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Canon imageCLASS D320 Digital Copier Logo
248 people viewed this question
old marine
old marine
