Question about Yard Machines Red Edger
Do I need oil in the gasoline on the 3 hp motor?
  • 279 Answers
It should say in your manual if the engine is a 2-cycle or a 4-cycle. The 2-cycle would need oil in the fuel, the 4-cycle would not...Good luck...Lee
Posted on Oct 03, 2009
What type oil for model 90234 4 HP 10 gallon
The model number is not enough info but assuming it's a run of the mill, Home Depot or Craftsman type electric air compressor, you need to buy compressor pump oil at Wal Mart or an auto parts store. Please don't use Automotive motor oil because that's not going to withstand the heat of your compressor pump and you'll be buying a new compressor because of it. If your compressor has a gasoline, 4 Hp. motor, it needs Mobil 1 synthetic and change it after every 30 hours of operation.
May 19, 2017 | HP Air Tools & Compressors
How do l fix an outboard motor that runs fine for about 5 minutes at full throttle and then abruptly stops and will not start until it sits for awhile?
Check that the priming bulb is fitted with the arrow pointing in the directions of flow to the engine. Make sure the vent is open on the fuel tank. Check all fuel lines for kinks or blockage. If none of that fixes it, you need a marine engineer to check the fuel pump and carbs.
May 13, 2016 | Boating
I just bought a 1998 5hp 2-stroke Johnsons motor and was just wondering what's is the best mix for it?
While the two cycle oil has it on the back of the bottle but with my 1998 I would pure a bottle in it or depin on how much gas you got I like my gas kind of a blue tint
Feb 08, 2015 | Boating
How much oil would i ad to a pint of gas at a 50 to1 ratio
A pint is 16 ounces, add 1/3 ounce of oil for a 48:1 mixture.
Gary
Aug 30, 2011 | Vacuums
Need to know what type of oil and how much to add after change of old and what type of gasoline...really was looking for owners manual
does not use motor oil, oil gets mixed in with gas, and it's a 50:1 ratio usually. regular gasoline, not high test
May 20, 2010 | Garden
How do I change one gallon of a 50:1 gasoline mixture to 40:1?
  • 40:1(gasoline:oil) ratio requires 3 ounces of oil.
  • 50:1(gasoline:oil) ratio requires 2.6 ounces of oil.
  • So for you to change to 40:1 you need to add .6 ounces of oil
    Apr 01, 2010 | Garden
    I am looking for a homelite super 2 service manual
    Hello JC;
    I suggest add a post that includes an email address here:
    ArboristSite Beg for manuals thread (free to join)
    http://www.arboristsite.com/showthread.php?t=72322
    This is a reply to a similar request.
    http://www.arboristsite.com/showpost.php?p=2087444&postcount=5565
    I have not found a good source for Homelite OMs, you can make a request here:
    Homelite.com Contact Us
    https://register.homelite.com/contact_us/new
    If you do the above please request they add a link where anyone can download an OM. If they reply with a link to all OMs PLEASE post that back here.
    If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
    Lou
    Mar 20, 2010 | Electrical Supplies
    Repsol MOTO Gasoline Motor OIl,4T,Sintetico synthetic blend 10W40
    Repsol Moto 4T Sintetico Synthetic Oil - 10W40
    Synthetic blend lubricant with high thermal stability, designed to meet the needs of the most technologically advanced 4-stroke motorcycle engines.
    • Excellent starting and lubrication in cold conditions due to its low viscosity.
    • Meets JASO MA API SJ requirements.
    Its fine to change your oil with synthetic, Just be sure that you use synthetic from now on... I don't think its advisable to switch back to regular oil after using synthetic.
    Apr 29, 2009 | 2005 Honda VT 750 Shadow Aero
    Lawn mower motor
    No it's sounds like the float in carb is stuck I've had 3 motors do this I put a fuel shut off in the line after I cleaned the carb out and rebuilt it. The problem is the gas breaking down an gumming up the float in carb. Drain the oil and an run some oil thur it to get the old gas out make sure you clean the carb out to.
    Sep 20, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Yard Machines Red Edger Logo
    95 people viewed this question
    Top Yard Machines Garden Experts
    dannydoesita
    Phil Walker
    Phil Walker
    Dean Gruber
    Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
