Question about Frigidaire PLD4375RFC Dishwasher
4000 Series Aquasurge diswasher, ER code came up
4000 Series Aquasurge diswasher, new purchased 8/16/09 read ER then VO
Noise while filling-sounds like relay engaging then disengaging and then reads: ''ER'' ''VO''
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Posted on Jan 22, 2010
Electrolux 24 in. Diswasher
Hello Darlene, thank you for allowing me to assist you!
The "ER" code that keeps appearing on your Electrolux dishwasher stands for a Membrane Switch Failure. Normally that means that your control board has detected a stuck key or key pressed for more than a minute. That could possibly be an issue with your keypad or main control board. I would recommend having a technician come out to your home to properly diagnose and repair your dishwasher. I hope this is helpful. -Matt
Aug 02, 2014 | Electrolux EIDW5905JS Dishwasher
Found an oval rubber gasket in bottom of 4000 series AquaSurge with speedclean dishwasher model PLD4555RFC3. Look to go inside dishwasher but cannot locate where
Hello, Thank You for using FixYa. I will be helping you today.Here is a parts break down of your model CLICK HERE See if you can locate it im not aware of an oval gasket.
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Frigidaire Dishwashers
Frigidaire Aquasurge, panel is flashing, cannot
I would suspect a faulty touchpad/console. They get moisture in them and short out causing all sorts of problems.
Mar 23, 2010 | Frigidaire Dishwashers
I own a frigidaire professional and the low light stays on what is wrong? Professional Series Aquasurge with Speedclean
the low light refers to the rince aid being empty. fill it back up and the light will turn off
Feb 05, 2010 | Frigidaire Dishwashers
I bought a brand new 42 inch plasma vi vo tv 2
New products do fail. The set should certainly be under warranty. I would speak to the dealer you purchased the unit from and see what they suggest. Don't remove the rear cover, or do anything else to give anyone a reason to void your warranty. Most brands are 90 days on parts and labor.
Nov 25, 2009 | Televison & Video
Frigidaire 4000 series dishwasher error code
This is likely an indication of a problem with the circulation pump motor under the dishwasher like maybe a bad circulation pump motor but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Grinding noise for maytag quietseries 200 usually when it first starts up
I had the same problem with my Maytag Quiet Series 1 dishwasher until I read the comment left by the guest on June 1, 2008. I tried his suggestion about the rinse cap adjustment and WOW it WORKED. No more growling noise. Thanks you saved me a service call.
Apr 06, 2008 | Dishwashers
Error code ER then UO any ideas?
So far so good. I fixed mine by removing the vent and even though it says no repairable parts I disassembled it then removed the rubber gasket and cleaned it with a brush under hot water. I then cleaned the plastic ring it seals against. Next I removed the spring and stretched it to make it about a quarter inch longer and then reinstalled the spring then the rubber gasket and then closed up the unit. So far it is working fine. I suspect the real problem is that there is a tiny sensor that needs to be covered when the vent is closed. If this is not covered the uo error code is generated.
Apr 22, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire PLD4375RFC Dishwasher Logo
2,148 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
