Question about Jenn-Air JMW9530C Electric Double Oven
I have a Jenn Air SVD48600W dual fuel stove. Electronic push button panel will not accept anything that is getting pushed-in. Clock unit was replaced about 1 yr. ago and then this problem of not accepting anything that is pushed-in started. Could this be the control panel?
    President:
  • 1,304 Answers
It is indeed your control panel
it shopuld be covered under the 5 year warrenty
Posted on Oct 03, 2009
I have a jen air propane oven and four stove burner and it is flashing a the code f7-1 and saying call a a tech. Please help the beeping is very annoying
Hi, the error code implies that the Function key shorted or stuck..
You need to replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 20, 2010 | Jenn-Air JJW8530C Expressions Collection...
Jenn-air electric double control does not work - clock is on
Disconnect the Power Supply for few minutes, say 30 minutes and then Turn the Oven ON.
Do you see any Error Message?
How old the Unit is?
Do you have any Experience to Fix this?
Do you have all the tools?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 30, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I need to know to set the tempature on my jenn air range oven this is a push button ove n
i decided not to try to fix it i think i would have to buy a complete panel, to fix it that would cost nearly as much as a new stove
Jan 29, 2010 | Ovens
Electronic touch panel unresponsive. Clock blinks, but no other commands produce any activity. Model#:JMW8330DAS Serial #:13679516JN Jenn-Air oven. About 2 years old.
Unplug and let sit for 5 min. Replug and set clock time first. Then see if the other buttons work. Electronics sometime need to reboot if it freezes like your computer does sometimes.
Apr 29, 2009 | Jenn-Air JMW8330DAS Stainless Steel...
Faulty timer function on Stoves 720 EF
To take off the front button panel.
First power off the cooker, then remove the three right control knobs - they are just push on and push off. There are flats on the spindles matching contours on the knobs to ensure thay go back correctly.
Lower the top oven/grill front. Under the front button panel there are three screws going upwards. One at each end and one in the middle. Remembering how they are installed, remove them. The panel will now be loose but it is held in postion by two or three lugs which are along the top inside edge of the panel. They, from what I remember, hook into the inner panels of the cooker. I think you have to lift the lower edge of the panel towards you, to overcome the upward bend of the lugs.
The buttons for the clock are purely push fit and if you want they can be removed using a thin bladed knife.
I have to say that if you want complete access to the clock, I think you will have to take out the complete oven from the unit and take the top off, so be warned. Instructions of how the cooker is mounted are in the instruction manual.
Putting the front panel back I found to be fiddily - ensuring the lugs are located correctly, especially the one by the clock doesn't always want to work. In the end I left that one not positioned correctly, so in effect the front panel is slightly out at the left hand end.
Best of luck!
Jan 28, 2009 | Stoves 720EF Electric Double Oven
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JMW9530C Electric Double Oven Logo
229 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
