Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Change out timer.
How do you get the knob off of the timer to change it? do you just pull it off or what? tried but no luck.
Well how do you fix a timer knob, i just had a new one shipped and I put it on too, like the old one and it does the same darn thing, I can turn it and it cliks and i can put the know where i want it but it won't push in.
Lacy
Posted on Mar 04, 2010
    Scholar:
  • 196 Answers
Try twisting the knob counter-clockwise and see if it will come off. If not, look at the timer knob and see if it has a two piece front. Sometimes you have to pry a small cover from the time to get access to the holding clamp.
Posted on Jan 08, 2008
Removing timer knob on maytag washer mav2755aww
It unscrews or if it is a newer model, remove the console so you can tip it forward. You will see a (usually black or white) pin in the center of the timer, pull it out about and inch and then remove the knob from the front by pulling it off the timer shaft. Check you new timer and make sure it comes with one. So did some did not. Good luck.
Mar 28, 2016 | Maytag Washing Machines
General Electric WHDSR209DWW Top Load Washer. Timer works but has lost proper synch with knob and skirt. Can force timer to a position that will run the machine from an unknown starting point. When knob...
Hello:
Its either your knob is stripped or the timer itself is..Most commonly its the knob assembly that's bad.(part# WH01X10061) I would try it first since the knob is only around $7.00 where the timer is around $140.00or so...
Good luck
Jun 04, 2017 | General Electric WHDSR209DWW Top Load...
How to replace timer knob on Maytag PAV 2300 aww, old one snapped off leaving just the stem
This is from another site but does a good job of explaining how to change your timer:
http://www.the-appliance-clinic.com/myttimer.html
The hardest part will be swapping the knob because you have to lift the top of it off and sometimes they can be fiesty.
WORDS OF CAUTION.
DO NOT pull all the wires off of the OLD timer. DO a ONE for ONE wire swap. i.e pull one wire from the old timer... and hook it up to the new one on the exact same terminal as the old timer.
Kelly
Mar 22, 2011 | Maytag PAV2300 Top Load Washer
How do you get the dial off of the timer so you can change it out with a new one. I tried pulling it off but it will not budge. my model # is nav2335aww
On the backside of the timer is a stick that slides inside the hollow timer shaft. When it is shoved all the way in it spreads the tip and retains the timer knob. Back the rod out a about a half inch and the knob will come off.bd28a28.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 05, 2010 | Amana Washing Machines
Washer does not change cycles on its own
timer is most likely bad if it will not move on its own at all..
3951703 - TIMER
you can access the timer by:
remove power from the unit.
remove the philips head screws that should be present in each left and right control panel end cap front.
slide the control panel bottom forward 1/2 inch and lift up.
the entire console will swing up on the hinges in the rear of the console top.
with the console upside down you can see the back of the timer, there is a small brown clip sort of recessed into the back of the timer that is connected to the timer knob/shaft. that clip needs to be pulled out so that the knob can be removed to access the screws on the front to remove the timer assembly.
around $100 new
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
Gets stuck in cycle I have to turn the knob to get it to continue. The machine is the heavy duty large capacity I can't find a model #
Looks like you need a timer. If the model number is really gone there should be a part number n the timer. look everywhere around the door/lid and even on the back. Eric
Aug 12, 2009 | Washing Machines
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Replacing timer
  • push the timer in and turn it counter clockwise. this should unscrew it.
  • if that does not work, check the back of the timer for a black plastic tab. pull it out to unlock the timer knob from the timer.
  • there are many different styles of timer knobs.
Jun 29, 2008 | Frigidaire GLWS1349A Top Load Washer
Timer knob
some models you remove center cap on knob and pull pin out others you need to remove screws in console and lean in forward to acess rear of timer push knob in pull small pin in back of timer and then pull knob off
May 21, 2008 | Maytag Performa PAV3200
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
89 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
