Question about Garden
I have a fx26 weed eater that won't keep running. I have replaced the spark plug & one fuel line...it will start on choke, but will die when I put it on run...can you help?
  • 130 Answers
SOURCE: 25cc weed eater, will only idle
i have found out over 25 years fixing small engine carb are lot of the problems.rebuild the carb and clean real good blow out real good it will go back working fine the diapham go bad.allso change fuel filter to put new gasket between carb and block.let me know if this help you.please.
Posted on Jul 25, 2009
  • 62 Answers
SOURCE: poulan ppb 250 weed eater, only runs with choke on,
HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
Posted on Sep 25, 2009
MOTORWIZJ
  • 1358 Answers
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
  • 4 Answers
SOURCE: stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Posted on Jun 19, 2011
Why won't my FeatherLite FL-20C weed eater will not stay running when I put it in full choke. What could be wrong?
It should run ok after warming up. After starting it, let it run for a minute or so and then try gradually opening the choke. You might try increasing the throttle setting at the same time. After the motor is hot, if you have to have the throttle setting increased in order to keep it running it means the idle setting needs to be increased, usually by turning a screw to keep the fuel valve from closing so much, or that there is a problem with the fuel flow......like a clogged jet or fuel passage in the carb.
Jul 07, 2014 | Weed Eater Featherlite Fl20 Lawn Edgers
Toro weed eater starts but then stalls out
A few things to check, clean or replace:
  • fuel filter - located inside the fuel tank
  • Spark arrestor - located at muffler
  • Spark plug
  • Carburetor
Mar 08, 2014 | Garden
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weed Eater Problems
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
May 17, 2010 | Troy Garden
ECHO 2000 WEED EATER I changed the fuel line,
You may need the carburetor adjusted or rebuilt. The other possible item is "bad gas". If the gas has been sitting around longer than 30 days, it may be time to mix up some fresh fuel mixture.
HTH
Good Day.
Oct 29, 2009 | Garden
Garden Logo
233 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
