Question about AEG B4101-4 Electric Single Oven
Oven temperature no controllable
Oven temperature not controllable
. think themostat may be the problem. is it easy to replace thermostat
    President:
  • 1,304 Answers
Runaway temp
very easy its just the probe on the back wall
should be about 30
and 10 minutes of your time
Posted on Oct 03, 2009
Testimonial: "Many thanks, have removed it and order new one."
Tricity Bendix SE556SV lower oven not reaching tempature, new element, themostat and fan
First need to see if supply voltage is correct.
Verify oven probe sensor to the thermostat Is working properly? (usually done by Ohm test)
Thermostast offer an option for calibration?
Also have you verified actual oven temperature with an external thermometer?
Jun 09, 2015 | Ovens
Frigidaire oven overheating
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
Why is the oven temperature incorrect?
The oven temperature control is usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.
Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.
On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.
Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
Feb 12, 2014 | Frigidaire Ovens
Thermostatic switch fo 30 year old tricity marquis double oven the oven heats up but the temperature control does not work.
More than likely a faulty thermostat, I doubt you would get a replacement for a cooker of that age.
I would recommend that you seriousyl think of replacing the cooker.
Dec 09, 2010 | Ovens
XL 44 Gas Range Oven temperature problem
hi If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: Install the new thermostat using a reverse procedure.
Nov 06, 2008 | Ovens
AEG B4101-4 Electric Single Oven Logo
220 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
