Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Refrigerator icemaker won't work and refrigerator fills with wate
Kenmore Refrigerator icemaker won't work and frig fills with water.
  • milten1
    milten1 May 11, 2010
    your ice fill tube may be out of alignment
    and the ice machine isnot getting any water to it
    President:
  • 1,304 Answers
Check your fill tube you might have an ice build up on the end
the fill tube is where the water dumps into the ice machine
Posted on Oct 06, 2009
Water to icemaker overflowing; won't stop
you have a defective fill valve controller and only a repair service can fix it properly .
Feb 28, 2018 | Kenmore 21.7 cu. ft. Top Mount...
Bought house with frig in it not used for a while fridge works fine turned on water for ice maker water works does't make ice
Is icemaker switch and light on? If so check for plugged fill tube. If not, the water valve or icemaker will need replacing.
Sep 25, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Have a kenmore side by side. seems the icemaker does not have enough water and sometimes it works and sometimes it does not work.
if you have a water filter change it out. or you water vavle where it hooked up on back off frig lower back side may not be working right
Apr 11, 2010 | Kenmore 53642 / 53644 Side by Side...
My icemaker works slow to make ice. Sears Kenmore side by side refrigerator. Model.57572791
check temperature in freezer compartment,needs to be near zero,if it is,there may be a problem with the internal thermostat on the icemaker,also checkthat the icemaker mold is filling completely with water,all the cavities should fill
Jan 22, 2010 | Frigidaire FRS26H5AS Side by Side...
ICE MAKER STOP WHEN FILTER GOT CLOGED
Run the water from the frig for a while to make sure the filter has run out all the air. The filter needs to fill with water first and then fill the line to the icemaker before you will get ice.
Apr 29, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore 106.78202890 Ref. Icemaker seems to work fine. No water leaks when it fills but I have water in the refrigerator section that seems to be draining from the freezer. Any ideas?
Hi there, I believe you may have a defrost drain problem. See the water has to drain somewhere else when the drain is stopped up. So instead of into the catch basin on the bottom of the frig it cascades down the backside of the frig and ends up under the crispers. To fix the problem you must clear the defrost drain. It is located beneith the evaporator coils. When the frost on those coils melt it turns to water. Remove the freezer access panel, and clean out the drain. Use some hot water or a shop vac.
Jan 12, 2009 | Refrigerators
Ice maker output very low volume
Hi!!! check your filling tube line going into the icemaker its a white tube that gives water to the icemaker.It might be plugg of ice..get a hai dryer and aim it for 30 minutes good luck..
Jan 05, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
No water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Too much wate flow into icemaker
it over filling or it leaking from the mold i never seen thi model over filled mold when i see wtr in bin is usually the mold that is leaking you can check with a mirror or remove to inspect is texture is peeling off repl entire ice maker if is ok then repl wtr valve is not closing when it has filled the mold you only need 4oz of wtr
Nov 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side frig with icemaker
The water smells funny and taste moldy/musty. Where is the filter to change it? I've looked inside and out and can't find it.
Jul 14, 2008 | Kenmore 53082 / 53084 Side by Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
133 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
