Question about Samsung TV Remote Control
Remotecontrol for TV samsung CB-3351x. dont even know if there was one. howe to know?
  • johejo Oct 06, 2009
    Never had one.But would like to have one.
    I do not know if the television is remoteable or if
    the funktion is broken.but i have tried several types of multiremotes whith no responce at all.
  • James Chavez May 11, 2010
    What I need is the brand and model of your remote control. Thanks. JimmyC
What is code for Seiki TV?
that is because sony remote is not a universal and will only control the original sony which it was sold with
Feb 09, 2016 | Sony Televison & Video
The wiring came off and don't know howe they go by color it'got5 places to salder wires are r/b/or/b
If your asking about a Cobra radio then these links will have the pin-outs plus wiring color code for different mic's.
I had to guess what you was asking for as your question was kinda vague. And a Cobra 29 is a 4 pin mike, not 5 pin.
The 148 - 142 were 5 pin. I'll include it also.
http://www.cbtricks.com/radios/cobra/148gtl/index.htm Cobra 29LTD ST 29WX ST
Aug 13, 2015 | Cobra 29 LTD CB Radio
Howe to wire a 4 pin coard on a astatic d 104
must know the pin out of the transceiver your wiring it too.
like cobras 1.ground 2.audio 3. TX 4. RX... then wire accordingly.
use a ohm meter to find the correct wires on you mic switch.
then you know how to wire any mic to any transceiver.
Sep 02, 2014 | Radio Communications
WHICH REMOTE MATCH CB-20F4 SAMSUNG T.V
dear sir
hamare paas Samsung ka tv hai jiska model cb-20f4 hai isme kaon sa remote match karega
Feb 04, 2013 | Samsung TV Remote Control
Samsung AK59-00123A remote to a M261VP vizio tv
Hello
[1] Switch your television on
[2] Point the remote control towards the
television
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
Sep 20, 2011 | Zenith ZEN700 Remote Control
Tv loosing channels every time i push my tv remote to channel 1
It can be some problem with the remotecontrol, try to config the control and check the code to it, i'm sure you'll be able to find the code on the internet. Good Luck //David
Jul 29, 2009 | Samsung LN32A330 32 in. LCD TV
Remotecontrol-codes
I got lucky and found one at my local markedplace :-)
Jan 05, 2009 | Sony BDP-S350 Blu-Ray Player
How to get my RCA universial remotecontrol codes...
if none of the codes work try contacting remotes.com for the original remote control
Nov 25, 2008 | Televison & Video
Emerson Remote with Philips TV
I like using original = part # 312814713331   cost 35.00.
Or go on-line to Emerson ? remotecontrols.net? ......T,
Oct 24, 2007 | Philips 27PT8419 27" TV
Samsung TV Remote Control Logo
67 people viewed this question
Henry  Thomas
Henry Thomas
