Question about Exercise & Fitness
Coaster wheels under the seat riding rough
Abcoaster....coaster wheels under the seat riding rough.draging & clicking while sliding up & down.wearing out the poliurathane-wheels
    Habit-Forming:
  • 115 Answers
I think you will have to replace the wheels. the clicking noise in the bearing in the wheels are failing. make sure to lithium grease the track the wheels ride on this protect the new wheels and make the machine move smoother
Posted on Oct 09, 2009
How do I disengage coaster break on jeep x16 full suspension bike?
You have to replace the rear wheel or take the hub apart and remove the shoe for the brake. Best to go to a bike shop and purchase a wheel or see if they can replace the hub with a free wheel hub.
Nov 10, 2014 | Jeep 16" Boys Full Suspension Bike
I have a 20" inch girls kent trouble bike. How do I take the rear wheel off?
remove the coaster brake lever bolt. This is small bolt that holds the coaster brake lever to the left side chain stay. There will probably be a strap wrapped around the chain stay with bolt going through the strap and the lever. This usually requires a 10mm wrench (sometimes it is 8mm) for the nut and a Phillips or flat head screw driver (some times it's another 10mm bolt head).
The axle nuts are usually 15mm nuts. Loosen these (they usually don't need to be removed all the way) and push the wheel forward to put some slack in the chain. Lift the chain off the rear cog and you will be able to pull the wheel out of the drop outs.
To install, slide the wheel into the dropouts, put the chain back on the cog, pull back on the wheel and tighten the nuts finger tight. Reinstall the bolt through the coaster brake lever and then tighten the axle nuts, pull back on the wheel while tightening the nuts so the chain is tight. Then tighten up the coaster brake lever bolt. (if you tighten the axle nuts first, you won't be able to move the coaster brake lever into place to get the bolt in)
Aug 18, 2014 | Cycling
Where is the battery on my riding lawn mower
either under the seat or under the hood in front of the steering wheel. Clicking when attempting to start?
Jun 03, 2014 | Craftsman Garden
Rough ride and sliding on snow
Hi Susan, This sounds like a tire problem. I find on my Suby's, that too wide a tire will tend to struggle with deep snow. An out of balance tire or out of round wheel can also make the car run rough. There is also the possibility that the car needs a wheel alignment. Have someone check out the steering components as well, to make sure there's not a more severe problem, i.e.: axles; ball joints; steering arms. This is critical so you can be sure your vehicle is road worthy.
Feb 05, 2014 | 2004 Subaru Forester
When riding the peddles slip,it appears that the chain is engaged and that the axle is slipping and make s the peddles spin, not engaged
If this is a coaster brake bike (single speed, no hand brakes) then the problem might be inside the rear wheel hub. If that is the case then you can only fix it by completely dis-assembling the rear wheel hub - or it might be simply that the chain is slipping, which would not happen unless the chain is too loose which would be indicated by the bottom of the chain hanging down too low. However, if this is a multi-speed bike, then it could be that the chain and rear-wheel cogs are worn - which can be fixed by replacing the freewheel and the chain - however, it takes a lot of use or rust and dirt before that level of wear happens.
Aug 07, 2012 | Trek Mystic 16
The brakes are getting stuck and the wheel doesn't tuen
You do not say what kind of bike, speed bike?Coaster brake? hand brakes, pedal brake? If, it is a hand brake, it usually means that your wheel is bent and needs to be trued. You cannot adjust brakes with a bent wheel and you need a truing stand.. If it is a coaster brake you need you hub rebuilt as there is an part broken inside the hub.
Apr 16, 2011 | Schwinn Cycling
Wagon wheel/ 10'' pheumatic
The "pressure caps" have most likely created a burr on the shaft which you will need to either sand or file down smooth before it will slide off easily. Try rubbing your thumb and forefinger around the shaft and you can most likely find a rough spot. Slide the wheel as far back out of the way as you can get it and take a very fine file or better still some emery cloth to get it smooth.
Sep 26, 2009 | Northern Industrial Tools Northern...
Front wheels making clicking noise and lug nuts are seated ok
Not Good! You have the Wrong size Lugs on that Van Or they were Loose while Driving. If the Wheels are Wearing that way, You will need to Replace the Wheels and Lugs to fix this Problem.
Jan 22, 2009 | 1999 Dodge Caravan
1999 GMC Jimmy Rear Brakes
check the axle end play. if there is significant axle in-out motion, this will cause excessive inside pad wear. it will also cause the caliper to bind under breaking conditions, yet slide freely when there is no stress applied
Jan 19, 2009 | 1999 GMC Jimmy
DRUM RUBBING
It could be a number of things to cause drag on the drum. A rear bering or front slides sounds like the most common. The front slides are small plastic like parts that the drum rides on around the door area (GE Part Number GHPWE1M333). The rear bering is located on a stud that protrudes from the center of the rear of the drum. Remove the belt and slide the drum straight out. You will see the bering stud mounted to the drum. The bering will either be on the stud or still inside the bering holder in the rear of the dryer itself. Look for signs of wear or a torn bering. Grease shaft very well when replacing. Also, look for signs of wear inside the dryer to where the drum would be rubbing the case or cabinet. Both these berings are pretty inexpensive and if you have the know-how, easy to replace as well. Good Luck!!!! Jim
Sep 08, 2007 | GE DCSR483EA Electric Dryer
Exercise & Fitness Logo
108 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
