Question about Panasonic PANAFAX UF-6000 Fax
The machine goes to fax too quickly before I can respond to the telephone call
Use programing code to be entered digitally or set switch on unit.
Posted on Oct 04, 2009
What's error 345 with HPOfficejet j5780 all in one while faxing?
error 345 while faxing is related to Communication error. This error is not related to printer hardware issue.
Below are the possibilities ....
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted.
  2. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted.
  3. The remote user pressed the Stop key while the reception was in progress.
    The suggested solution would be as follows....
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Jun 02, 2014 | HP Officejet Pro L7680 All-In-One Printer
When I plug the telephone line into the Fax machine the telephone line goes dead
Verify that telephone cord from the wall is plugged into fax port labeled LINE. The port labeled PHONE is for a spare telephone set.
Dec 18, 2012 | HP Photosmart C6150 Wireless All-in-one...
Our fax machine keeps saying "busy/no signal" even when we know the machine we're trying to send to isn't busy. Please give us some suggestions as to how to correct this problem. Brother...
Verify the connectivity (phone line) first by pluging a working telephone in the wall jack, than test the cable from the wall jack to the fax, you could install a Y to plug a working telephone with the fax on the same line to spy on what is happening when the fax is engaging a connection.
Hope this helps!
Jan 05, 2011 | Brother Office Equipment & Supplies
When send out a fax, I got line error with my Sharp UX 106 fax machine. Thanks.
check that the connections are done properly telephone cable from wall plug goes into "line" input on fax machine and cable from telephone goes into "tel" on fax machine if this is correct then check that your telephone line has no problems ie. noise or line dead this is no good for comms to TX
Oct 18, 2010 | Sharp Office Equipment & Supplies
I can send, but not receive faxes
Try calling your fax machine from a telephone...if the fax machine does'nt respond, unplug the fax and plug a phone into the fax line and call again to see if the prob is the line or not. If the line is ok make sure your fax machine is set to "FAX" and not "TEL".....if all this fails think about when it stopped working....did you just have a storm or power outage.???? The NCU pcb in the machine may be damaged.
Apr 19, 2010 | Office Equipment & Supplies
Receiving faxes
If you are receiving a fax and you pick up the telephone before the fax machine answers it, the fax will never be able to respond to the fax being received. I assume that is whats happening. If you have a phone connected directly to the fax machine and you pick it up from that phone, the fax machine should transfer to itself after 2 seconds when it recognizes that it is a fax machine.
If you are going to do it from anywhere else, you need to get a fax detector device connect it to the main phone jack, and have the fax machine go to the fax jack of the connector and the other phone in to the other lines, make sure you have enough sockets on the fax detector.
thanks
May 07, 2009 | Office Equipment & Supplies
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
I can't figure out how to set up my fax machine so it won't mess up my phone and answering machine either.
Telephone wire goes to fax, out to answer machine, Important to set fax on answer machine mode and set the ring count to pick up AFTER the telephone answer machine. Set fax ring count to 5 rings, and answering machine to 3 or 4. When some one calls answer machine or you pick up first, then if no one will leave a msg. fax tones are different than voice tones, they are called CNG tones. Most new fax machine will sense this and if a fax will go to fax only. Ring count is the key. Also you could set fax up for maual mode and would not jump to anser machine or fax till you want.....good luck
Aug 28, 2008 | Office Equipment & Supplies
Fax wont send
try sending to another machine and also from a different telephone line if possible.Also does this machine receive a fax.Noise on telephone line can cause such problems.
Feb 27, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Panasonic PANAFAX UF-6000 Fax Logo
96 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
