Question about HP (dc197x) CD-RW/DVD-ROM Combo Drive
Cd drive is not opening
Hi..I am using windows XP professional and SAMSUNG 52 Max Cd Drive.
My Cd drive is missing when i try to open. If i try to run a cd the drive is disappearing. It is not showing even in device manager. If I restart the system Cd drive is coming back and disappearing again if i try to run a cd.
Please Help me to solve this.
Thanq
    Guru:
  • 81 Answers
Uninstall the driver from Device Mgr, then go to registry editor, browse to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the left hand side delete the Upper and Lower filter. Restart the PC and reinstall the driver. You may also create new user account if issue continues.
Regards,
Shrey
Posted on Oct 06, 2009
Hi sir can help me for product key of windows xp pro sp3.tnx
HI,
You can find the product key. just follow these steps. Insert Windows XP cd into a working computer. Exit the Auto-run introduction.Open "My Computer" Right Click on the Windows XP cd-rom drive and select explore.Open the USWXP32P_ZX folder. (It may be as a hidden folder. If you cannotlocate the folder, you may also search forunattend.txtand mark "Search Hidden Files".)Open the sysprep folder. Open unattend.txt Your CD's product key is containedwithin the unattend.txt file.
Jun 06, 2011 | Microsoft Windows XP Professional
Computer won't start up - says file missing or corrupt: \windows\system 32\config\system. cannot open cd=rom to use original set-up CD
That folder contains all of your Windows files, so your operating system is no good anymore. So you have to reinstall Windows. It sounds like you have the disc so we just need to get that drive open. To get your CD drive open, you have to use the override system. On most CD drives, there's a little hole on the front. Sometimes it's hard to see. What you need to do it get a paper clip and straighten it out. Then stick the paper clip in that tiny hole. Keep going in until you feel a little catch, then keep pressing. This will mechanically open you CD drive. Just put the disc in and close it up again. Hopefully your reinstallation of Windows will work out. Best of luck!
Apr 12, 2011 | Microsoft Windows XP Professional
I would to know my DVD drive, Lite-on DVD C LH52C1P can write or burn any DVD disc? my OS is WIN XP Pro SP3
Here's the general info for your Burner:
Write support: CDR CDRW Read support: CDR CDRW DVD- DVD-RW DVD+ DVD+RW Operating System supported: Windows 7 Windows VISTA Windows 2003 Windows 2000 Windows 98 SEWINVISTA Windows XP Max Write Speed: 9 MB/sec. CD 52 X Max Read Speed: 9 MB/sec. CD 52 X DVD 7 X
Jan 15, 2011 | Lite On LH-52C1P Burner
Toshiba Protege 4004 recognizes a CD-R (52X, 700 MB) blank disk in the drive, displays dialog box "choose program to open the file". Running Windows XP professional, 2002 I want to format the CD, then...
you are getting this message, because it has viruses.
You can open this by selecting inernet explorer from the menu or Open my computer and go to address bar and select CD Drive from the drop down menu. it will open. use a usb harddisk or flash drive to take the back up of your system.
Feb 15, 2010 | Computers & Internet
I am having trouble running setup on my desktop
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
Aug 28, 2009 | Computers & Internet
Have a Dell 667Mhz 64mbit ram pc w/windows 98 on
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Mar 29, 2009 | Samsung SC-148 CD-ROM Drive
CD will not eject from drive
image1-main_full.jpg Hi Gerald,
There is nothing wrong with Files or Windows Xp, your CD-DRIVE is stuck. There is a small whole on front panel of the Drive, try to put a long needle in it to get shutter out. Alternatively you can take help of any hardware professional, it will take only 2-3 mins.
Thanks
Zulfikar Ali
Jan 27, 2009 | Roxio Computers & Internet
Message: "No Disk in Drive"
hi tip53
it seem you had problem with optical cd/dvd drive, open your Samsung sw 240b, under the optic there's potentio try to adjust it by twist to left slowly.
may help
goot luck.....
Jul 23, 2008 | Samsung SW 240B CD-RW Burner
CD Rom not recognize
Nov 18, 2007 | Samsung (SC-152) Internal 52x CD-ROM Drive
Windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
HP (dc197x) CD-RW/DVD-ROM Combo Drive Logo
85 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
