Question about Syntax 427V 27 in. LCD Television
Lots of vertical lines. Please see attached link for pictures of the TV while powered on. I read a similar problem where the owner contacted Syntax and they told them it was the digital tuner. However, I would assume that i could get some responce from the menu buttons and such. I get no responce from anything, the screen simply displays this. But, when I turn it on, it does scramble the digital converter that I have hooked up to another TV in the room. Is that normal? http://i692.photobucket.com/albums/vv289/dizzytats/olevia427v2.jpg http://i692.photobucket.com/albums/vv289/dizzytats/olevia427V3.jpg
  • 2 more comments
  • Dain Epperson
    Dain Epperson Oct 03, 2009
    no whining noise there
  • Dain Epperson
    I took off the back panel as well as the cover for the imput board and there is a constant red light above a reset button. With the power on, I press the reset button and the screen turns off, then soon comes back on, along with the light. Is this simply signaling that nothing is plugged into the imput board? Or is this what is making the vertical lines in my screen, and making the TV inoperable? Below are links to pictures of the screen while on via photobucket (vertical lines)
    http://i692.photobucket.com/albums/vv289...
  • Dain Epperson
    how can i identify the xus board? where is it typically located? what is the size? anything will help. I searched google and i noticed that some have "XSUS" marked on them. do all?
  • Dain Epperson
    Dain Epperson Oct 04, 2009
    I beleive I found the problem. When I took the board up, none of the capacitors were swolen, but on the stainless steel underneith the board there appeared to be a burn mark right below the capacitor. I'm going to buy a replacement now.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This is an issue with the loose connectors on the X-sus board, this may also happen due to faulty components on the X-sus board. You'll need to check the connections to and from the X-sus board.
Also make sure that the capacitors on this board are not swollen.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 03, 2009
  • Rylee Smith
    Rylee Smith Oct 03, 2009
    Hi
    X-sus board will look like this---
    Clcik to zoom in. You can order one from this link--
    Syntax 427 Series tv parts
    If you don't have expertise in these kind of repairs or will not be able to replace or access the board then i'll suggest you to check this link--
    Syntax Tv repairs
    You can also call (718)787-1301.
    Thanks
    Rylee
    President:
  • 1,922 Answers
Do these lines accompany a high pitched whistle/ringing sound/tone, if so i would say your flyback transformer is running wild or the windings are loose inside the flyback itself
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Black vertical line on p42w34p plasma
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 31, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Vertical lines on screen kinda pixelated
Just check this link. You can see similar type of fault to LCD TVs. Compare them to that of your TVs and make sure. It sounds that the LVDS cable has loose contact with its connection sockets. Re-seat it once, and check.http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 03, 2013 | Polaroid Televison & Video
Vertical line flashes on tv screen
Picture problems are surely among the most common technical issues experienced by home TV viewers. Such problems may manifest themselves as pixelization or frozen pictures, intermittently flashing pictures on one or more channels, static or audio degradation, or channels that are missing altogether. To address these problems, you can always contact the technical support department of your cable TV provider and have them walk you through troubleshooting steps, but it is wise to learn how to fix problems like this on your own without consulting any outside help. Doing so can save you lots of valuable time and money in the long run.
1.Reset your cable TV equipment by unplugging the power cords of any digital cable boxes/DVRs you use in the home. Count a full 30 seconds and plug the equipment back in. After allowing the device enough time to complete its boot cycle, check the picture again for any improvement. A cable box in need of a reset is by far one of the most common causes of many different picture degradations, so this is a necessary first step.
2.Check the audio/video connection cable or cables that attach your cable service equipment to your TV. Loose or malfunctioning cables are also a very common cause of picture degradation. Secure any cables that may have come loose and replace any visibly damaged cables. If you think the cables may be failing, you can temporarily test them by plugging another audio/video connection cable from the cable equipment to the TV and checking for any improvement.
3.Scan through your entire channel lineup as well as all the input channels on your TV. This will help determine the scope of the problem and how to most effectively troubleshoot the issue further. If you see the vertical lines on only one or a few cable channels, the issue is much more likely with the broadcaster or your cable provider, and you will need to report the issue to your provider. If you see the vertical lines on all channels and all video inputs, it is more likely that the TV's picture components are beginning to fail, and you will need to have the TV serviced or replaced altogether.Thanks for using FixYa, hope this will help your problem.
josie
Oct 19, 2011 | Televison & Video
I have an Olevia 242TFHD LCD tv, and there is a faint black line running vertically from top to bottom on the right hand side. There are also occassional red and blue lines running horizontally. The tv is...
You may have failing T-CON board. you will get more lines as time goes by. Try cooling it with freeze spray for electronics troubleshooting.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 02, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
I have thin line going across the screen.what could my problem be?
Your tv has lost vertical deflection. This can be often caused by:
- bad connector contacts (oxydized pins) on the deflection coil connector at the picture tube neck or on the circuit board - in or around vertical drive section
- bad solder contacts on connector pins or on any of the components in the vertical drive section or elsewhere on the board (power supply to the vertical drive section)
- faulty or badly soldered vertical drive IC or transistor
- other faulty or badly soldered components in the vertical drive section or in the power supply line for that section
You can read more about this kind of malfunction at:
http://www.repairfaq.org/sam/tvfaq.htm#tvsinghli
Hope you can fix it...
Regards,
Triarcuate
Oct 20, 2009 | Televison & Video
Picture tube has a horizontal line across the screen but not picture, just the sound comes through. I can sometimes regain a picture by quickly turning on and off the surge protector switch, but lately is...
You are experiencing a lack of vertical deflection or vertical collapse. Since it will come back the first thing I would suspect is “ring cracks” in the solder joint in the vertical circuit, mainly the vertical IC. These suspect solder joint can be re-soldered and the television set repaired.
I would suggest that you contact a local servicer. If you are repairing the set yourself, be careful, there is always a risk of shock when dealing with electronics.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
May 15, 2009 | Sanyo DS27510 27" TV
Single horizontal white line on screen
This is either bad connections at the vertical IC or a defective IC. This should be a small flat IC attached to a heat sink. It will be marked LA7837 or something similar. It will have about 11 pins. If you are not sure you have the correct one, post the marking here and I'll confirm.
Dan
Nov 17, 2008 | Symphonic ST427FF TV
JVC Interiart 32" Digital TV. No longer turns on. Has a thin horizontal line across screen when TV is on. No picture.
The thin line indicates that there is no vertical. This is usually controlled by a single IC (vertical IC). Look for a small flat IC attached to a heat sink with 9-14 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC with a new one.
Keep us posted.
Dan
May 09, 2008 | Televison & Video
Tv picture dose not come only LINe
There is a problem with the vertical circuit. Many times it is the vertical IC. This is a small flat IC attached to a heat sink. It may be merked LA7838 or something similar. You ca try resoldering the pins as a bad connection can also cause this. If that fails, replace the IC.
Keep us posted,.
Dan
Apr 30, 2008 | Televison & Video
Syntax 427V 27 in. LCD Television Logo
57 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
