Question about Rinnai EnergySaver 556 Air Conditioner
Rinnai 556 F sputters when starting
I followed your instcutions and found the items but the glass peep hole seemed to be attached with small rivets and didn't appear to be removable. I cleaned everything well with a big shop vac and then started the heater observing the flame through the peep hole. It came on and made a loud sputtering sound and the flame was yellowish red but after 10 seconds or so of fluttering the heater started and a two tone blue flame coud be seen. The flame was darker blue close to the base of the flame and lighter blue at the outer edges but looked healthy.
Is there a way to adjust the startup to eliminate the flutter and sputter ? Sometimes it will fail to start and I get the flashing red light.
  • 1,420 Answers
There is a way to adjust the flame, but you will need a monometer to do it. I would suggest getting in a gas technician to adjust your gas pressures. You do this for both low and high pressure.
Posted on Dec 24, 2007
  • 98 Answers
As a licenced plumber the only thing I will suggest is to call someone and have them service the heater.
Gas is deadly, and it sounds like there is something blocking the injector port, causing the gas/air mixture to not mix properly, which will make the flame change colour and characteristics.
The burner may need to come out, the inlet gas pressure will need to be checked and other things.
The rinai heaters are also expensive, as you would know, and trying to fix it yourself is dangerous. Also, once serviced by a plumber you will have the peace of mind to know it has been serviced properly and will run well for many more years.
You will need to find a licenced gas fitter.
Posted on Dec 23, 2007
My rinnai 556 will not start, the only light is with the child lock pressed, on/off does not light? any ideas?
HI, Dear your rinnai 556 is not starting thats why it can not genrate the error code ,i advice you in this case you can not identifiy the exact problem. but i m trying to help you with my best tring:-
What you need to do -
Check the model number and serial number which are found on the data label located on the bottom of the right hand panel of the unit. Any Rinnai Energysaver Models RHFE-556T and RHFE-556FTRG Gas Air Warmers with a serial number contain the the year (YY) digits "00" to "07" may be affected. If you cannot read the data label or think you may have an affected model do not use the Air Warmer and inform anyone who may use the Air Warmer that they should not do so. Contact the Rinnai freephone helpline for further instructions, even if you have not experienced any problems
HELPLINE 0800 0304 556 or you can visit or email if you have any further questions.
The helpline staff will validate whether you have an affected product and will arrange for a Gas Safe Registered Engineer to visit and replace the gasket in the air Warmer.
i hope this will be helpfull to you. PLEASE DON'T FORGET TO VOTE ME. GOODLUCK..............
Jan 21, 2011 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
The rear passanger window fell into the door. I lifted the glass and taped it so it stays up, but I would like to fix it so it properly works. what should I do?
you'll need to remove the door skin
you will see where the window attaches to the regulator
it is usually held together by two rivets
if you cannot find the replacement rivets, typicaly a dealer item only, you can just use small nuts and bolts
Apr 05, 2010 | 2002 Ford Explorer
My Rinnai says not to use it without an air filter and to clean the air filter once a week--but I can't see an air filter. Is it possible that it was installed without one?
If you have a RHFE263, 431 or 556, the air filter is located at the top in the seam where the wall trim piece attaches to the heater. It looks like a dryer lint filter.
Feb 15, 2010 | Rinnai EnergySaver 556 Air Conditioner
Rinnai 556 ftr keeps flashing code 12
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
2004 Mercury Monterey left frnt window sector gear R&R proceedure
are you a techie? You need a heavy duty riveter to do this repair. May have to rent or borrow from auto store.
here's the procedure
Front Door Trim Panel s4w~us~en~file=adobe.gif~gen~ref.gif Printable View (251 KB) NOTE: LH side is shown. RH side is similar.
  1. Remove the parts in the order indicated in the following illustration and table.
  2. Item Part Number Description 1 23942/23943 Mirror access panel 2 1722897 Cup assembly 3 W56904-S424 Window regulator control switch panel screws 4 14A665 Window regulator control switch panel
    Removal Note 5 W701930-S424 Front door trim panel screw 6 W701930-S424 Front door trim panel screw 7 N602703-S61 Front door trim panel screw 8 1723943 Front door trim panel 9 W705590-S300 Nut insert(s)
  1. To install, reverse the removal procedure.
Item 4: Window Regulator Control Switch Panel Removal Note
  1. If equipped, disconnect the electrical connector(s).
Door Window Glass — Front s4w~us~en~file=adobe.gif~gen~ref.gif Printable View (328 KB)
Special Tool(s) s4w~us~en~file=st1132a.gif~gen~ref.gif Heavy Duty Riveter
501-D011 (D80L-23200-A)
  1. Remove the front door trim panel. For additional information, refer to Section 501-01 .
  1. Position the watershield aside.
    To remove individual parts, only carry out the listed steps: Part Steps Front door window glass 1, 3 Front door window regulator 1-5 Front door glass run 1, 3, 6-8
Item Part Number Description 1 W706495-5100 Rivet (2 required)
Removal Note
Installation Note 2 N8621986 Nut (3 required) 3 21410 Front door window glass 4 W706495-5100 Rivet (4 required)
Removal Note
Installation Note 5 23200 Front door window regulator
Removal Note 6 N800507-S Bolt (2 required) 7 21596 Front door glass run 8 — Front door glass run (Part of 21596)
Item 1: Rivet Removal Note
  1. Connect the window control switch.
  1. Connect the battery.
  1. Position the door window glass halfway down to gain access to the door window glass rivets.
    • Remove the rivets.
9391398.gif Item 4: Rivet Removal Removal Note
  1. Remove the rivets.
Item 5: Front Door Window Regulator Removal Note
  1. Disconnect the electrical connector.
  1. s4w~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Prior to power window motor removal, make sure the regulator arms are in a fixed position to prevent counterbalance spring unwind. Failure to place the regulator arms in a fixed position can cause the spring to suddenly release resulting in personal injury.
    NOTE: The counterbalance spring assists the window in the upward direction.
    Remove the bolts and the window regulator motor.
Item 4: Rivet Installation Note
  1. Using the special tool, install the rivets.
Feb 21, 2009 | 2004 Ford Freestar
Looking for Manuals
Google rinnai 1004 and 556 manuals. I just did and found them
Nov 26, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
606tr rinnai silent server
You are not getting gas for some reason. Check the valve to make sure it is getting power to open the solenoid. It may need to be set to on. If you are getting power to the valve and its not getting gas, check the orifice. Sometimes a spider or other bug will get in there and plug it up. Its a very small hole, so it wont take much to block it.
Mar 01, 2008 | Rinnai EnergySaver 556 Air Conditioner
Rinnai EnergySaver 556 Air Conditioner Logo
192 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
