Question about HP DeskJet 970cxi InkJet Printer
My printer will not pick up the paper too print it just rattles and the orange lite flashes
    Guru:
  • 1,049 Answers
If it is the orange light blinking, it may be the ink. Be sure you installed the number 45 black and number 78 tri color cartridges. The 41 tri-color looks the same but will generate an error. Also, ensure that the cartridge is not empty or dried out. Also check that the duplexer, or the panel in the back if no duplex is installed, is seated correctly.
Posted on Oct 13, 2009
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
My printer stopped picking up/feeding paper. If I
try cleaning the pick up rollers , they must be a little sticky
Apr 03, 2009 | HP DeskJet 5550 InkJet Printer
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer cannot print.
HP Deskjet 1125c printer - Printer does not print. Bottom orange light keeps brinking. Paper cannot not even be picked up by the printer.
Jan 17, 2009 | HP DeskJet 1125c InkJet Printer
Hp deskjet 920c printer won't print.
hi,
i think your having problem on your ink carrier, maybe this are defective that's why you have a orange flashing lights..
Oct 27, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Out of Paper
make sure that the paper is kodak xtralife with perforated tabs, otherwise the printer will really not pick it up and if it would - it's gonna be a really bad print
detach all the things that are attached to the printer.
grab a piece of lint-free cloth, wet the other end and leave the other end dry
clean the roller horizontally
use the dry end to dry up the roller and watch for water build ups
have at least 10 photo papers in the paper tray
slide the paper tray back into the printer
plug the printer onto the wall outlet, wait for the initializing sound
put cam to the printer dock
print a picture
Jan 20, 2008 | Kodak EASYSHARE CD33 & Printer Dock Series...
Printer ripair
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
Feb 20, 2007 | Canon BJC 3000 InkJet Printer
HP DeskJet 970cxi InkJet Printer Logo
122 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
