Question about Sony VGN-CR309E/L Notebook
BATTERY PROBLEM I CHARGE THE BATTERY FULLY BUT WHEN I SWITCH IT ON AFTER A FEW DAYS BATTERY IS DEAD
  • 2,567 Answers
This is a typical indication that the battery has failed & need to be replaced. In your case, the battery cannot hold the charge.
Posted on Oct 03, 2009
Xantrex XPower PowerPack 300 will not charge even after replacing both battery and adapter. What else can I try?
Either charger has an issue or new battery is boogus. Check charger output for specs. Subject battery to a few discharge/charge cycles. If charger is definitely good and battery will not charge fully after a few cycles then you have confirmed that new battery is bogus.
Sep 06, 2017 | AMP Computers & Internet
After new battery put in, battery is dead in a few days.
When you shut down the car some circuit in the car is using current at an excessive rate so as to drain the battery. To repair you need to locate the source of drain. You can do this by connecting an ammeter to the car battery and while the car is turned off monitor the amperage reading. You will see a draw. Then pull fuses, one at a time, till you see the drain virtually disappear. Now you have identified the circuit that is responsible for draining your battery. If you cannot fix it, at least you know where the hassle is and you can always pull that fuse when you leave the car unattended for a few days so that the battery is not drained. If getting to the fuse is a hassle you can always replace the fuse with some wiring and a switch that you place in the glove box and all you do is turn the switch off when you remove the key. Presto - cheap fix!!!!!!
Aug 22, 2015 | Cars & Trucks
I have had my zeepad on the charger for a few days now and it is not fully charged. What do I need to do for it to recharge?
Probably, the ac charger unit isn't good anymore. Output charge voltage& current isn't sufficient to drive your battery charge beyond 80% threshold.
Change or replace this with a new one (same ac charger specs please) and charge your tab again.
Oct 09, 2017 | Tablets & eReaders
I have an Audi A6 19TDI Reg in 2001. after disconnecting battery on this car. and reconnecting after few days. the dasboard does not work, None of the Gauges are working. will not show speed, rev counter...
Take the battery off and fully charge it - get a hydrometer to test it - its pointless going on if the battery is the cause of the problem.
If the battery is fully charged and you put it back on and the dials are dead - you have a serious problem.
You could need a complete new dashboard assembly - I had a Renault where this happened and it was big bills time - a new dashboard.
In the old days rust killed cars - now faulty electronics kill them - a dash could be $750 or more an ECU to manage the engine could be more.
It might need a garage with the correct computerised test equipment to fully diagnose.
GOOD LUCK
Mar 10, 2011 | 2001 Audi A6
My roomba was not used for a month. Now it does
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Nov 29, 2009 | iRobot Roomba 560 Robotic Vacuum
My battery is draining. it will stay charged for a few days then the next day it will be dead. what is causing this?
Your battery may have a weak or dead cell thats drawing the charge out of the good cells...i would check this first. A fully charged battery will show 12.44 to 12.6 volts on a digital multimeter. You can check the charge of the indivual cells with a hydrometer. Make sure your battery terminals are clean and secure...the ground to frame will corrode and make poor contact over time.
Good luck...i hope this helps..please rate me a fixya
Jul 29, 2009 | Honda CRF 250 X Motorcycles
After leaving my Sony DSC-T2 camera unused for only a couple of days the battery was flat. I recharged it fully but again it only lasted a day or two. I assumed the battery was dead and I purchased a new...
If the troubleshooting section in the back of the user guide doesn't help, I sugget getting in touch with Sony and asking them if it's normal, the only thing I can suggest in the meantime, is taking the battery out while it's not in use, or recharge it a few hours before you're due to use it. Phones get like it after a few years and with technology advancing the way it is these days, you'd expect a battery life lasting longer than a week, not a day.
Things to consider:
1. When it's off, is it off or left on standby?
2. Where did you buy both the camera and batteries from?
3. When you charge it up, do you charge it up with a half charged battery or a totally dead battery?
Jul 20, 2009 | Sony Cyber-shot DSC-T2 Digital Camera
Battery keeps loosing charge- kymco cruiser 125, 2005
I had this exact same problem on a hipster 125, it was a faulty regulator module ( mounted under the seat) I also found a short circuit (somewhere) in the wiring loom between the regulator output and the chassis (probably what killed the regulator in the first place!) I cut and replaced the entire wire to save removing most of the loom and after testing reg to ensure it was dead i fitted a new one (about £60) bike charges and runs like a dream now even with fully lights approx 80% of the time. good luck
Jul 14, 2009 | 2005 Kymco Hipster 125
My battery went dead this morning i charged it this evening and it is just showing a battery and timer wont switch on or charge??
from what I hear, you have either fully charged your battery or your battery is pretty much completely dead.
your options:
1. If it's completely dead and won't hold a charge it's time to purchase another battery, this happens from time to time so don't freak out about it.
2. If it's fully charged, try taking the battery completely out of the phone, and re-inserting it after a few minutes, sometimes cell phones need to be reset.
3. ensure that your charger is working properly, if its not getting juice to it neither is your phone.
4. try to dial your number just to see what happens to the phone.
5. if someone else u know has a charger like yours try to borrow theirs to charge your phone possibly ruling out a bad charger
Nov 13, 2008 | Samsung Cell Phones
Sony VGN-CR309E/L Notebook Logo
43 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
