Question about Dell AMD 386/33 Desktop Computer 333S/L Motherboard
I have a Dell Latitude C400 Laptop. it will not load Win XP
I have a Dell Latitude C400 Laptop. When i boot up it says there is no operating system press F2 OR F3. when i try to load winxp it still comes back to the same message
  • 89 Answers
Try to make sure that all the cables are connected properly and that your hard drive has enough memory. Then make sure that your Windows XP DVD is not corrupted. Another thing you should try is loading a different OS like Vista or Windows 7.
Posted on Oct 05, 2009
SOURCE:
Dell latitude c400 model PP03L, how to install xp no cd/dvd and don`t see usb from bios
If you already have an USB flas bootable with XP on it, plug in into the laptop, and when the laptop starts, press F12. Then you should select that the computer should boot from USB. If this won't work, try to attach an external DVD\cd unit.
Nov 04, 2009 | Dell Latitude C400 Notebook
Windows XP corrupted - Why can't I reload windows
You have to change the bios settings for making it boot from usb device. look at boot menu on the bios/usb cd-rom
Oct 10, 2009 | Dell Latitude C400 Notebook
Getting error code 1000-0141 on dell latitude c400
User your win xp disk in the drive and boot it. At the command prompt typed chkdsk and then press enter.
Should find and fix any problems it comes along to find...Hope this helps!
Dell latiyude C400
The system is in a reboot loop. Possible causes are:
Corrupt installation of Windows
Bad Hard Drive
Bad RAM
Bad Motherboard.
Try booting to the Windows XP CD, see if you can access recovery console and run CHKDSK /R If that doesn't resolve, boot to the resource CD, and run diagnostics on the HDD
If you can't, boot to the XP CD or Resource CD, try removing the HDD and booting to the CD. If the system boots then, the HDD is most likely bad.
If you can't boot to any device, try RAM modules individually, see if system boots with only 1 module installed. If no change, then motherboard is bad. On a system this age, I do not recommend replacing a motherboard as it is not cost effective
Jun 22, 2009 | Dell Latitude C400 Notebook
Network Boot
hi,
i have dell c400 laptop, its to much simple to install xp
first you just take out hdd from laptop
plug in tht hdd in desktop pc by external usb box
now u just start windows 98 setup in it
when it started first format ur drive then install it
when windows 98 setup files copies to 100%. machine need to restart
u just plug out the hdd and plug in back to laptop
now the setup will remain start in ur laptop and when the installation complete u just upgrade ur windows from 98 to xp by intalling xp from external drive on OPERATING SYSTEM OF 98 WINDOWS
NOW WAT U SAY???
ITS TO MUCH SIMPLE just try once
Jan 29, 2009 | Dell Latitude C400 Notebook
Dell c400 loading xp
Did you sysprep the system?
You should only load the drivers that are needed to make the system run the basics. Don't worry about the network card unless you wish to install windows updates. I recommend just installing the OEM version of XP and modifying the registry to add drivers.
HKLM Software Microsoft Windows CurrentVersion "DevicePath"
Leave whatever is in there and add all the drivers to that folder. Make sure to include the motherboard drivers for the Dell laptop followed by all the other drivers. Some drivers will contain sub folders and you need to specify those as well spaced out by semi colons.
This should be all pasted in the devise path and it should look similar to this.
%SystemRoot%\inf;c:\dell_drivers\C400\Audio;c:\dell_drivers\C400\Video;c:\dell_drivers\C400\Video\XP_32; ect ect ect... if there sub folders in the drivers that are zipped, unzip them to the directories that you created on the root of C.
Once you have finished downloading all the drivers and modified the DevicePath registry key then download SysPrep from microsofts website and select Mini Setup and Shut down check boxes. Once the system shuts down then put the drive into the other laptop.
The system will be setup to install XP on the C400 with the drivers you included from the registry and the paths you pointed them to pole. On newer systems with Sata drives and other specific types of hardware like RAID you will need the hardware ID and adding that to the answer file for sysprep but that is way more complicated! For a DellC400 you will not need to do that.
Dec 22, 2008 | Dell Latitude C400 Notebook
WALTER I NEEED YOUR HELP!
You can watch a bios screen load up maybe even tinker around with it, even boot something off a cd, but you still need an operating system( Like windows) To really use your computer
Oct 24, 2008 | Dell Latitude C400 Notebook
Won't boot from new hard drive
simple prombelm of this is this computer wasn't made to start from xp ,it need start from a ealier system like windows 95/98 see the 386 file is prombally missing that why it wont boot up. lala linda
Oct 15, 2008 | Dell Latitude C400 Notebook
Dell C400 Resolution Problem
Boot into BIOS and go to the Video card setting, that sould fix it
Jan 26, 2008 | Dell Latitude C400 Notebook
DELL Latitude C400
Go to the Dell website and download the XP video and display drivers:- http://support.dell.com/support/downloads/devices.aspx?c=us&l=en&s=gen&SystemID=LAT_PNT_P3_C400&os=WW1&osl=EN
Feb 22, 2007 | Dell Latitude C400 Notebook
Computers & Internet Logo
137 people viewed this question
Clive
Clive
Alun Cox
