Question about Garden
How do you replace the o ring on a pressure washer
  • 98 Answers
Very carefully
Posted on Mar 17, 2010
How do I fix a leak in my pressure washer
f it is at the fittings for the pressure hose , replace the "O" rings
if in the hose , replace the hose
if it is any where else pull it apart and replace the "O" ring or gasket
Jun 22, 2016 | Washing Machines
I replaced water seals and now i have an oil leak. however i have good pressure
I don,t nothing by the brand of this pressure washe but i think there is also a large round oil seal is maybe broken or is not good or ring is not in his seat. but a cuff-kit has most times has not the 3 oil seals on the pump cover under the brass pumphouse this are the first rings simmer rings but before you have no problems with oil leak , are they not forget ? look carefully on the image of the cuff-kit or on the site of the brands models spares . if the brass pumphouse was released then you have replace the 3 simmer rings oil seals yet.
Oct 03, 2015 | Annovi Reverberi AR SJV2.5G27D-F7 Pressure...
I HAVE A 2600 SIMONIZ GAS PRESSURE WASHER AND I HAVE LOST PRESSURE. CANT FIND THE PROBLEM.
Hi Trevor
You have one of two problems
1. Pressure relief valve is stuck and needs cleaning or replacement
2. Pistons that pressurize the water need new sealing rings or seals
Bud
Sep 28, 2013 | Karcher 2500 PSI Pressure Washer
Coleman Powermate pressure washer. Model PW0751310 A lot of water leaks out in the handle where you squeeze for the unit to work, thus the power spray is weak at best. Took handle/arm apart and didn't...
There may be orings in gun but usually not available as a repair kit. Replace the gun with a 5000 to 6000 psi. You will get a much longer life by over sizing gun. If you like to tinker, you can by orings at Lowes in the plumbing department. Lube the orings with silicone paste (also sold at lowes). Good luck
Mar 17, 2011 | Caterpillar Cat Pump Pressure Washer Pump...
Pressure washer lost pressure in the middle of a job
The pressure valve has stuck in the high pressure position. This prevents anymore inflow and hence no further water will be pumped.
Rebuild the valve... There are O Rings to replace and clean the bore with croocus cloth. Lube the O rings with plumber's grease... good as new! 15 minute job. Get EXACT sized O rings for the unit.
May 16, 2010 | Honda Pressure Washer PSI 3000
McCulloch FH160G Pressure washer has a weak spray. Unable to locate my owners manual.
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FH160G-6096160G04-966989801.pdf your owners manual. Most likely the gun needs replacement or you can take it apart and replace the necessary o rings. These are common issues with this type of pressure washer.
Apr 21, 2010 | McCulloch FH160G Pressure Washer
My pssure washer the pump will not kick on so i have very low ater pressure
If you take the valve body on the pump apart very carefully you may found a broken return spring or a blown out rubber o-ring if the engine runs but the pump doesnt pump high pressure check your pressure relief valve sounds like its stuck open.
Apr 17, 2010 | Comet BXD2527 Pressure Washer Pump
Where can I purchase oil rings that go into the spray wand of a McCulloch FHH18A electric power washer.
I assume you mean the rubber O rings inside the wand. I had to replace mine as well. I had to visit several plumbing supply stores to find one that fit. I ended up taking the end of the wand with me so I could make sure the O ring fit. The ring you are after is a number 5, but you need to make sure it is thick enough to make a good seal.
Sep 10, 2009 | McCulloch FHH18A Electric Pressure Washer
Water leaks out at water pump and i just replaced the o-ring
you may have cut o ring when you replaced. coat with vaseline next time before assembly.
Apr 10, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
