Question about Canon PowerShot S5 IS Digital Camera
The lens has extended and now wont go back in. It wont work. It says, Lens error restart
t00nz
  • 4738 Answers
SOURCE: A460 lens error, restart camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 03, 2008
SOURCE: Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Posted on Apr 22, 2008
SOURCE: My lens wont fully extend
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Posted on Jul 01, 2008
SOURCE: Lens Error - Restart Camera : Lens remains in extended position.
Hey,
I had the same problem as everyone else regarding the error that would pop up stating that there was a lens error. I had the camera in my pocket when I went to a hockey game, pulled it out to take a picture, and it didn't work. Needless to say I was pissed because I expected far more from Canon. I was just about to go and buy a new camera, and figured that I would try to troubleshoot the problem and stumbled upon this site. Someone suggested turning the camera on and off while twisting the lens, so I figured it couldn't hurt to try it.
Before trying this, my lens would not retract all the way, the cover would not shut, the image was blurry, and I could not zoom in at all or the camera would show the error.
So, I tried the "twisting" solution, and it wasn't working, but I think I was being too delicate with it. I put a little more pressure on it and gave it a good twist. There was a clicking noise as others have said, but in the end, it worked after about 2 or 3 minutes of messing with it. No my lens goes down, the cover shuts and its clear as a bell. Not sure if this is a recurring problem as it appears to be a common problem, I fully suggest trying this before you send it off to get it fixed for a ridiculous amount of money.
Best of luck
Posted on Jan 30, 2009
ginko
  • 19396 Answers
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
Lens error.. I have restarted & restarted camera..still same lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 20, 2010 | Canon PowerShot A420 Digital Camera
I keep gettin lens error restart camera on my canon powershot sx100 and the lens wont retract. I have turned it on and off several times now. Is there anything i can do to get it working again?
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jul 21, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens wont retrack/ camera wont turn on...
Jun 15, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
"Lens error, restart camera." The lens won't close,
Jun 04, 2009 | Canon PowerShot A560 Digital Camera
I had the same problem with the same camera. Ended up twisting the lens by hand back and forth while powering the camera on and off till the lens pins finally realined and let it close properly. Took alot of patience and care but has worked since. Usual cause of this problem is powering camera while the lens is blocked from extending, ie in a case, laying on its face etc.
May 28, 2009 | Canon PowerShot SD870 IS Digital Camera
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens wont move
Apr 17, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
I need to restart my camera there is a lens problem
Mar 26, 2009 | Canon PowerShot SD1100 IS Digital Camera
Says lens error restart camera
Jan 06, 2009 | Canon PowerShot A590 IS Digital Camera
How do i restart my canon camera?
Restart means turn it off and on. But I believe that you failed to mention the other words that go with this error, namely "Lens Error, Restart Camera". Sadly, restarting the camera usually does not work to correct the lens error.
Oct 11, 2008 | Cameras
Canon PowerShot S5 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
