Question about D-Link DI 514 Wireless Router (DI-514)
When I change the web port and reboot the router, I can't access to that again
  • 20 Answers
You can reset it to factory default settings. There should be a very tiny hole at the back of the router. Using a paper pin press and hold on a switch button inside the tiny hole for at least 10 seconds and then release. Make sure when you do this router should be ON. After the reset, turn it off and then turn it ON again. Connect your laptop or desktop to it and now you should be able to access it. Remember to use defualt user name and password. They are usually admin / password OR no user name and password is password.
Give it a try.....
Jamil
Posted on Oct 03, 2009
I know my password and username but it says invalide username and password
Either you've (1) entered the credentials incorrectly, (2) remembered them wrong or (3) someone has gained access to the router and changed them.
You can solve this problem only if you have physical access to the router. You should locate the reset button on the router itself. This may be recessed to prevent accidental contact, and if so - will require depressing it with a pointed object such as a pen. Performing a reset will wipe all customized settings and restore the router to factory defaults. This means you will not have wifi access to the router or internet *if* you have changed it from the original factory setting. If you are attempting this via wifi, you will need to know what those wifi settings are or connect the computer via CAT 5 network cable to one of the LAN jacks or ports on the router. Once you have found the the default wifi settings - or - have plugged the computer into a LAN jack, reboot the computer. Next, press and hold the reset button for 30 seconds while it is plugged in & powered up.
This will start the restoration of the factory default settings and cause a reboot the router. The PC will obtain an IP address automatically if connected by cable - or prompt you for the wifi's SSID and security code after it boots up. Enter the wifi factory defaults to gain access to the router and internet.
Next, gain access to the router's "set up" pages. The set up page is usually access by opening your web browser and typing 192.168.0.1 or 192.168.1.1, or similar private IP address in the address bar. Your manual will have these details. If successful, you will be prompted to provide the router username and password. Again, the factory defaults are in your manual - popular username defaults are "admin" or "root" and popular passwords are: ""admin" or "password"
If successful, you're "in". You should make changes as necessary to prevent others from gaining unauthorized access - again. Do not reuse any of the previous credentials if possible. This means you should (1) change the password (and admin if allowed) fields to something only you would know and do not use words that appear in a dictionary. A mix of upper and lower case letters, numbers and symbols should be used. (2) Change the SSID to something other than the default. (3) Choose the option of NOT broadcasting the SSID. (4) Select WPA or WPA2 security. WEP is NO longer considered secure and should not be used. (5) Create another "password" for the WPA security as prompted. You will have to update every device that you wish to give access to the internet; this includes laptops, tablets, game consoles, wifi enabled cell phones, etc. You can make other changes as needed - as these are only the bare *minimum* changes you should make. Be sure your changes are saved before moving to other set up pages or rebooting the router.
Finally, write down the router's admin, password, SSID, security type (WPA or WPA2), security code and the IP address on a small piece of paper. Tape it to the underside of your router. This way, it will remain out of view but readily available to you should you ever forget this information and will save you from having to do all of this again.
Feb 26, 2014 | Computers & Internet
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
How do i make nat open
You have two options:
1. You can open port using router's web interface. Check what ports used your software, what protocol TCP/UDP then go to web interface's virtual server and add new user's rule. Then you have to save and reboot router. Every time your PC IP changed (static IP recommended) or program you using changed port number you have to do web interface operation again.
2. Download and install Router Commander (fully compatible with your router) and that's all. The software will forward ports automatically.
Dec 21, 2010 | D-Link DSL-G604T Wireless Router
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
How to forward port on telkom mega 100wr router
1. You can open port using router's web interface. Check what ports used your software, what protocol TCP/UDP/BOTH then go to web interface's virtual server and add new user's rule. Then you have to save and reboot router. Every time your PC IP changed (static IP recommended) or program you using changed port number you have to do web interface operation again.
Nov 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
My Belkin 4 port router has the same IP as my Modem so my router will not detect my DSL connection. Ive asked Belkin for help but all they send me is gobblygoop!
Hi!
I'm sorry to hear that Belkin did not help you with your problem. Let me help you with your concern instead.
Here's what we need to do:
Start by resetting the router to factory default - you just need to press and hold the rest button on the router for about 30 seconds (with the power on).
1.) Disconnect the Belkin router from your modem , connect a PC to the router (use the LAN port - either port 1 to 4).
2.) Open Internet browser - clear the address bar and type in http://192.168.2.1 , press enter. It will ask you for a password , do not type anything just press Submit. You should be able to access the router's web interface.
The router's web interface should like this (depending on the model #):
3.) Go to LAN settings. Change the router's IP address to 10.10.10.1 (this will be the new IP address of your router) . Apply the changes. Once youapply the changes, you can access the router using the new IP - http://10.10.10.1.
4.) Reconnect your modem - router and computers. Reboot device by switching off the modem , router and PC.
5.) Power up the modem first. Wait for about 2 minutes, power up the router and restart your PC.
The steps I gave is applicable if your modem is not on bridge mode. If your modem is on bridge mode (meaning it requires a username and password from your ISP) - access again the router by going to http://10.10.10.1 and do the following:
Click Internet WAN > Connection Type and select PPPOE. Type the username and password from your ISP. Apply the settings. Reboot the modem and router.
I hope that helps.
Good luck and have a nice day!
Nov 25, 2008 | Belkin Computers & Internet
D-Link DI 514 Wireless Router (DI-514) Logo
57 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
