Question about Kodak Easyshare M893 Digital Camera
I havent even had my camera for a year and it wont charge
If i cant find a way to charge it then im getting a new camera thats NOT kodak all of my cameras have been from kodak and they last less then a year because the door that holds the battery and/or memery card breaks so i have to tape and hold the door tightly closed when i take pictures.
my camera is a kodak M893 IS in purple
  • 300 Answers
SOURCE: Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Posted on Jul 25, 2009
BillB-SA
  • 2761 Answers
SOURCE: kodak MD863 digital camera will not hold a charge
The batteries may be tired and need replacing, but you go that route first try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
dlundmark
  • 797 Answers
SOURCE: i cant find any batteries that will last more then
Make sure that the menu setting is correct for the type of batteries you use, this can cause the camera to calculate for wrong battery usage.
Posted on Nov 14, 2009
leepania
  • 1099 Answers
SOURCE: how do i use m893 as a webcam?
Sorry that is unfortunantly impossible. A
webcam is cheap to buy anyways.
Posted on Jan 07, 2010
leepania
  • 1099 Answers
SOURCE: My Kodak Easyshare caemra will only hold 3 photos.
You need to switch the camera over to saving pictures directly onto the SD card.
1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If successful please give me the feedback as a rating or recommendation. Thank you
Posted on Jan 11, 2010
I have a kodak z650, this is "new" machine in the original box but we never used in the past six years. When then i turn on in the LCD showed "Kodak easyshare logo" then turn off by itself... The le
If you really left the batteries alone for 6 years without regularly charging them, they won't work anymore. I still have two KLIC 500 batteries from Kodak, which I bought in 2005, Both are in very good condition, because the both get a charge every 3 months, even in periods I did not use my camera.
You could try. charging the batteries several times, but don't have to high expectations.
Jan 03, 2014 | Kodak Cameras
My kodak easysharem575 wont work unless it is pluggedin even thouh i charged it
Still my guess is your battery is dead. There must be a reason you never get any guaranty on a battery. I do have two Kodak batteries KLIC-5001 from 2005. Both working as if they were new. But I also had to trow away (chemical waste) lots of NiMH rechargeable batteries, before they were one year old. From a very good brand. They never survived more than 25 charge cycles.
It could be, the contacts of your battery or the contacts in the battery holder of your camera are dirty or oxidised. Make sure the contacts are clean and shiny. Don't clean with a sharp tool. Just a dry cloth. I once found a little paper in the battery compartment, that disabled my camera for quite a while.
Nov 22, 2013 | Kodak EasyShare M575 Digital Camera
I havent used my kodak software for a long time. now im trying to use it and the sam thing keeps popping up"not a PNG file. whats wrong? what do i do? i have a kodak easy share P850. Help
Hello, Sounds like software fault, uninstall the software and perform a complete new install to see if this corrects your problem.
Best Regards, Russell
Jan 17, 2013 | Kodak EasyShare P850 Digital Camera
My kodak easyshare C813 wont tern on i havent used it for a wile help
Are the batteries charged? If no replace. Were batteries left inside while the phone was left idle? Try and scrape the terminals. Try switching it on if it'll work.
Dec 06, 2010 | Kodak Easyshare C813 Digital Camera
Camera wont even turn on, dont know whats wrong,?
Usually that indicates that the main battery needs replacement. The camera will detect the low battery charge and disable the flash.
If the camera is more than a year old or you take a lot of ppictures then this is most likley your problem.
Apr 05, 2010 | Kodak Easyshare C813 Digital Camera
My Kodak EasyShare M753's screen is white with black lines
That must have been caused by a drop and I'm pretty sure your screen is gone. Try to send it back to Kodak they may not charge you if it's not obviously physical damage, if they refuse to give you warranty service there are third party camera repair places but they will definitely charge you.
Dec 13, 2008 | Kodak Easyshare M753 Digital Camera
Cant get camera kodak m753 to charge
It appears that your problem lies with the main board their are two small fuses on the main board that can cause this problem. changing the main board is most likey your best bet repair on this can be around 65.00 and up depending on where you get it fixed.
Dec 02, 2008 | Kodak Easyshare M753 Digital Camera
Kodak easy share c 340
try taking out the batteries, and clean the connectors that the batteries touch, and the ends of the batteries (if recharagable). Sometimes a dirty connector can make the batteries seem that they are dead even if they are rechargable. If the camera works with new disposable batteries but not with the rechargable ones, then you may need to purchase some new rechargable ones.
Oct 23, 2008 | Kodak EasyShare C340 Digital Camera
Lens won't go back in, camera won't turn on
i have the same problem with my olymus camera. its agravating because mine wont turn on and the lense is sticking out. my warrenty is up so im thinking about buying a new camera? im not sure because it cost more to repair.
Aug 30, 2008 | Kodak EasyShare C340 Digital Camera
Kodak Easy Share DX 4530 won't hold charge any more.
Yes rechargeables need replacing from time to time (after a few hundred charges) or every couple of years.
You can use standard rechargeables but these wont charge on the dock as there is a little switch in the battery bay which the kodak pack presses.
Standard AAs ar'nt recommended for digital cameras but you should get at least a few shots from a new set of alkalines (maybe not if they are cheapo no Alkaline)
There could be another problem with the camera but if you like the camera its probably worth giving a new pack a try.
If I remember rightly (but check as I don't have a 4530 to hand) the battery you want is a KAA2HR and are available on ebay cheaply if you cant find a low cost one locally
If I can be of further help drop me a line
Best of luck
Apr 12, 2008 | Kodak EasyShare DX4530 Digital Camera
Kodak Easyshare M893 Digital Camera Logo
35 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
