Question about Nikon D90 Digital Camera with 18-105mm lens
Every once in awhile, our D90 hangs up and won't autofocus and take pictures. An error message is displayed but can be rectified by removing and putting back in the battery. The battery display usually says it's O.K (at least half full). Is this a battery problem or battery connection problem?
    Brigadier General:
  • 11,967 Answers
First, clean the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol. Then, do the same with the contacts on the camera body and lens where they meet.
Posted on Oct 03, 2009
Is the Tamron AF08N700 auto focus with the D90?
Good morning. You have likely already gotten an answer to this, but yes, it will.
Unlike less expensive models such as the D40, D60, D3000 and D5000, the D90 has a built in autofocus motor, which means that all Nikon F-mount autofocus-lenses (except two for the rare Nikon F3AF) can be used in autofocus mode for all newer generation autofocus lenses like the Tamron 200-800. However, you may want to look around a bit, as Tamron has come out with a new 150-600 lens that is simply terrific (I know, I own one) and the Big Sig from Sigma is equally great.
FYI
Good luck.
Dec 05, 2015 | Nikon DSLR D90 Digital Camera
What is error r02 on my Nikon D90?
r02 error have you tryed to fomate and remove Sd card
remove lens and replace remove battery and replace
you should be ok
Nov 25, 2012 | Nikon D90 Body Only Digital Camera
Nikon D90 flashed CHR and next time using camera LCD was black/grey with stripes and no pics HELP!!!
The CRH error message means that the lock tab on your memory card is in the locked position. The purpose for the lock switch is to allow you to set your SD card so that you cannot accidently erase your valuable pictures. Remove your SD flash memory card from the camera and hold it in your hand with the label toward you and the angled corner to the upper right. Look on the left edge of the card and you will see a very small slider switch. Make sure the switch is in the fully up position then reinsert it in the D90. If the camera is not generating a false error, your camera should work correctly.
Jun 19, 2011 | Nikon D90 Digital Camera with 18-105mm...
D90 - unable to shoot photo & remove lens from camera body
you must try to remove the lens that lens have some electric contacts and if you set the lens in wrong position that contacts give to the camera some error message
Feb 28, 2010 | Nikon D90 Digital Camera with 18-105mm...
Autofocus on Nikon d90 doesn't work well.
Remember, autofocus needs a difference in contrast to lock on to a subject. It's hard to focus on a solid color so move your camera slightly to find something better to focus on.
Feb 19, 2010 | Nikon D90 Digital Camera with 18-105mm...
My Nikon d90 monitor does not display when I turn it on.
By default the D90 is set to use the viewfinder for framing and taking pictures. If you wish to disable that and use the monitor, press the "LV" button on the back just above the multiselector.
Jan 20, 2010 | Nikon D90 Digital Camera with 18-105mm...
Error message F-- Nikon D90 w/kit lens 18-105mm
correct - i need to get a good grip on the lens and click it to connect to the body
Jun 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
D90 won't autofocus at distance
Mine seems fine. The only other thing I would think to check is the focus lock is off and the focus area setting.
Apr 28, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon d90 - can't take the picture
You just found the Nikon D90 F-- error message solution!
I had the same problem with the Nikon d90 F-- error message which drove me nuts!
I called Nikon, they walked me through a lengthy reset procedure which didn't work. After spending a few hours researching online, I found the answer.
It is not the memory card or nor a defective camera body. The lens does not need to be rechipped.
The F-- error means the camera is unable to communicate with the lens and is caused by a poor connection between the ground contact pin on the lens and the metal mounting ring on the camera. Most people buy the camera, install the lens once and then encounter the error. This one time lens installaiton does not give the contact point a chance to seat itself properly. You will find that if you hold down the lens release button and twist the lens as if to remove and reinstall the lens about 10 times that the problem will disappear. You don't even have to actually pull the lens away from the body, just press the release button and twist on and off and allow the friction to provide a better electrical contact.
Too bad Nikon doesn't tell their customers about this simple fix. Other than that, great camera. Good luck.
Dec 07, 2008 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 Digital Camera with 18-105mm lens Logo
333 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
