Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
I have recently bought a Belkin Wireless Router and I am unable to connect to the Internet on my laptop. What do I need to do to connect my laptop to the internet using the Belkin Wireless router?
  • jarginemaitl Oct 03, 2009
    I have looked on the back of my Router for the WAN port, but so far have been unable to verify which one is the correct port. My router model number is: Belkin F5D7234-4 v3. I have checked the specs online and can see that it says there are 4 x network - Ethernet 10Base-T/100Base-TX - RJ-45 / 1 x network - Ethernet - RJ-45 ( WAN ) / and 1 x network - Radio-Ethernet. There are only 5 open ports on the back. Which of the ports would be the WAN port?
    Scholar:
  • 82 Answers
Your Internet modem or router needs to be connected to the Belkin router's WAN port with an ethernet cable. You'll then need to configure the belkin's wireless settings, it's usually a very easy "follow the prompts" kind of setup.
Posted on Oct 03, 2009
  • Sean Gill
    Sean Gill Oct 04, 2009
    Typically the WAN port will be colored or labelled differently than the others. I don't have that exact model but from reviewing the product manual, the WAN port should be yellow and is the port on the end farthest away from the power connection.
Belkin router problems
Its not necessary to purchase a new router. Nintendo DS supports WEP encryption. You wont be able to connect if the encryption on the router is WPA. Your computer can connect on both WPA and WEP so what i suggest is for you to access the router page then check the wireless settings then change the encryption to WEP so that your Laptop and DS can connect at the same time. To access your router check the manual for the username and password
Thanks for using Fixya.
Aug 03, 2010 | Belkin (F5D5231-4) Router
Tip
Wireless Network Reset - Belkin
If you are unable to connect your laptop wireless to your <b>Belkin</b> wireless access point/router, the <b>easiest</b> and<b> fastest</b> way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.<br /><br /><br /><br /><b>Reset your router:</b><b><br /></b><br /> <ul> <li><b>Unplug</b> your <i>DSL/Cable</i> <b>modem</b> from power (not your access point/router) Leave this unplugged for now</li></ul><br /><br />Next <ul> <li>On the rear of your<b> Belkin router </b>you will find a small RESET button</li> <li>With the power still on the router,<b> Press</b> and<b> hold</b> (with a pin/pen tip) the <b>RESET</b> button for 10 seconds.</li> <li><b>Release</b> the RESET button a wait 15 seconds for the router to reboot</li></ul><br /><br />almost done.... <ul> <li><b>Unplug</b> your <b>Belkin</b> router from power</li> <li><b>Plug</b> your DSL/Cable <b>modem</b> back in to <b>power</b></li> <li><b>Wait </b>1 minute for the modem to boot up</li> <li>Be sure the ethernet (cat5) cable from your <i>modem</i> is securely plugged into the <b>WAN port</b> on the back of your Linksys <i>router.</i> This is usually labeled <i>WAN</i> or<i> Internet</i> above the jack</li> <li><b>Plug</b> your Belkin <b>router</b> back into power.</li></ul><br /><br />You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.<br /><br /><b><br /></b><i><b><br /></b></i><i><br /></i>Magoo
on Mar 13, 2011 | Computers & Internet
Cannot connect to my laptop. internet i working on my desktop computer. i have belkin wireless G router. i have unplugged the router but still unable to connect.
Once its connected you will have the blue light in the belkin router
1.Turn on the wireless switch in your laptop
2.Click on start menu--->control panel--->Network and internet--->Network and sharing
3. In the right hand side click on "Change adapter settings or Manage network connections"
4.You will see the wireless network connection
5.Right click on wireless network connection and click on Connect/Disconnect
6.you will be able to see the network name,try to connect it.
7.it will be connecting and then connected
8.try to able to go online in the laptop
Regards,
Ayyasam
Jan 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless Modem Router, model F5D7634-4.
If the reset did not help ,i would suggest you talk to the Belkin Support team and get a replacement. Since its a new router, I assume it has an up to date firmware .
Dec 16, 2009 | Belkin (F5D6230-3) Wireless Router
F5D8233-4v3 - Belkin Wireless Router
You must configure the wireless settings of the laptop manually. It should match the wireless settings of your router. If you have wireless encryption enabled, make sure to type the network key on the wireless settings of your laptop.
Jun 29, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
I have recently bought a Belkin 54G Mod Router so that I could use my laptop with wireless connection in another room while my PC remained wire connected. I have installed it as directed but I keep losing...
a couple of question for you, is your wireless secure or did you enable security features like wep or wpa, how many people authorise people are on your network. if not secure, secure your wireless network, hackers like to kick people off their own system, upgrade the firm ware on your router, for the latest compatibility it will fix issues that arise and finally do a bios upgrade on your laptop.
May 26, 2008 | Belkin Computers & Internet
Cannot sustain network or internet connection
It is quite possible that your issue is due to the DHCP function of your router. I would check the DHCP settings and the lease time that is set. Its quite possible that the lease time is running out and its having difficulty renewing a new IP.
Apr 24, 2008 | Belkin (F5D8231-4) Wireless Router...
D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Oct 31, 2007 | Computers & Internet
Network problem- Router setup cd cannot get past stage 1- No access to router
Do you have DHCP enabled on your PC? Sounds like you are not getting the IP address.
Oct 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
350 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
