Question about Pool & Spa
Drain Plug broke in half and is stuck
Hello. I have a pentair minimax ch heater. The drain plug broke off as I was trying to unscrew it. What are my options before the winter comes?
    President:
  • 1,378 Answers
If you can not get the pice still in the header out, loosen the flanges that hold the inlet and outlet pipes enough for water to drain and then tilt the unit so the water inlet/outlet side is lower than the other side. You may want to place a block of wood under the edge to kep it this way for the winter. Be sure to also remove the pressure switch to allow that tube to drain as well.
Posted on Oct 03, 2009
Pentair minimax ch200 won't turn on
if voltage to unit then check transformer if no replace if ok check safety circuit
Jun 28, 2014 | Pentair Minimax CH Heater
Where can I find helpful instructions for replacing (removing old and installing new) thermocouple on Pentair 250k minimax ch NG mv? Thank you.
Simple:
  • Insecure bracket holding the pilot assembly to the burner tray
  • now, remove the pilot assembly from bracketry
  • unscrew old pilot generator/thermo pile or thermocouple
  • new may have a clip instead of threaded nut
    • diameter of hole is same so it should just snap into place
  • in reverse order resecure the pilot bracket to burner tray
May 30, 2014 | Pentair 250k Minimax Ch Ng Mv Heater
Why is water dripping on burners of pentair minimax ch 200m?
bad heat exchanger or you have condensation this happens when the temperature delta is too high
May 21, 2014 | Pentair Minimax CH Heater
Heater stays on
rocker switch could be stuck closed
Jun 24, 2013 | Pentair Minimax CH Heater
Winterize minimax heater
Lost the manual to my heater. Would like to know how to
winterize the heater. mini max ch 250 M
bl.wilson @ hotmail.com .. thank you, hope you can help me.
Oct 03, 2009 | Pentair Minimax NT Heater
Pentair minimax 250 leaks onto burner
Unfortunately it is usually caused by a bad heat exchanger. Not too expensive, but a dirty, time consuming job to replace.
Aug 09, 2009 | Pentair 250k Minimax Ch Lp Mv Heater
Pentair Minimax 250M
how many times it blink will tell you what is wrong check at the codes. unplug thermostat check fo homs 10 k around is fine at 80 degrees pressure switch require a by pass but DO NOT RUN THE HEATER WITH A BY PASS ANY CONTROL!!!!
Jun 17, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
Pentair 250 CH LP will not ignite. Pilot works
to test the presure sensor jump the wires that plug in to the sensor if it turns on the presure sensor is bad and the the thermostat do you mean thermo sensor the one that checks the water tep follow the wires to were they plug in turn power off get your finger wet and put it were it plugs in on the 2 prong and turn it on the heater will light up if the sensor is bad
May 11, 2009 | Pentair 250k Minimax Ch Lp Mv Heater
Pool & Spa Logo
138 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
