Question about Mustek 6-in-1 Multi-Functional Camera Digital Camera
I have tried unsuccessfully to install DVB-T102 Freeview box. Is this model no longer usable after Sept 30 for Freeview channels?
Hi my Son has upgraded his old tv in bedroom to a Bush smart tv model no DLED32287HDCNTDFVP. I installed the channels first time. I have freeview channels except I cannot get the Sky channel to show?
When you say you have freeview channels, and then say you cannot get Sky channels this is not enough information that you have provided, but
I presuming in addition to freeview channels you also have a Sky Satalite receiver which is no longer connected to your Tv or your sons tv Either way Sky satalite have 2/4 lines which means you can have four viewings providing multi rooms is bought from sky, and additional boxes are fitted.
Or you can have 1 sky box main Tv and no the spare cable feed at the back of the sky box you can feed another cable to another tv from that same box but it will be same channels But you can now change channels using magic eye receivers etc, in any room.
But the question I believe is you had freeview but no long can receive sky channels the information is a little vague but hopefully I have helped a little
Sep 05, 2017 | Bush Televison & Video
How should I connect my denon avr 1906 to my 32" ES6300 Series 6 SMART 3D Full HD LED TV Model numberUE32ES6300U in order to get dolby digital from the tv's tuner please?
Use an optical cable.
Be aware though. Your TV has a DVB-T tuner. It picks up the Freeview standard definition (SD) channels, but not the Freeview HD ones. Dolby Digital sound only comes from the Freeview HD channels.
Your TV will pass Dolby Digital from any source connected to a HDMI port to the Optical Out. It will also pass DTS. But the internal Freeview DVB-T tuner doesn't generate Dolby Digital, just stereo and stereo with Dolby Surround encoding where you use ProLogic II for decoding.
Sep 08, 2014 | Denon AVR-1906 Receiver
Does the tv model sylvania tvk191 have a qam tuner?
If the TV is sold in the UK, then yes it has a QAM tuner.
All TVs have to be able to pick up Freeview to legally be sold as a TV in the UK. Freeview is the public name for the DVB-T service which is our Digital Video Broadcast - Terrestrial service. DVB-T is just the standard definition channels. DVB-T2 is the version of Freeview that includes HD as well as SD channels. The QAMs are the way in which the signal is encoded. But it's really a level of detail that you don't need to go to. It's sufficient to know that the tuner is ether DVB-T for SD only, or DVB-T2 to pick up SD and HD.
Sep 08, 2014 | Televison & Video
Does a samsung dv3 tv have freeview
Yes, it does.
DV3 is actually DVB meaning Digital Video Broadcasting. The stylised design of the DVB symbol makes it look more like DV3. If the TV has the DVB symbol, then it has a digital tuner and can receive digital channels, i.e. Freeview.
If you need assistance with tuning the Freeview channels or have further questions, please let me know the model number of the TV. This can be found on a label on the back of the TV.
Regards,
BElectric
Apr 24, 2011 | Televison & Video
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
Feb 09, 2011 | Televison & Video
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
Sony rdr hxd860 recently retuned on 30th sept 2009 as requested now lost program guide. not sure how to get it back
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 02, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Loss of BBC channels
Oct 01, 2009 | Philips TV Tuner Video Capture PCI Card -...
How do I retune my goodmans television for
Oct 01, 2009 | Goodmans W280NS Television
Mustek 6-in-1 Multi-Functional Camera Digital Camera Logo
35 people viewed this question
Top Mustek Cameras Experts
Mohamed Ismail
Mohamed Ismail
Steven Wander
Steven Wander
Are you a Mustek Camera Expert? Answer questions, earn points and help others
