Question about Dryers
Mi electric dryer is not heating, but the motor is working. What can I do?
  • 3 Answers
Hi there
it sounds like the heating element has gone in your tumble dryer, you can search the make and model on the internet and find the part, its easy to fix so should cost you a lot less than an electrician, make sure you unplug the appliance first
Posted on Oct 04, 2009
Mi secadora enciende pero no calienta
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 13, 2011 | Frigidaire GLER642A Electric Dryer
Mi secadora no tira aire caliente.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 14, 2011 | Whirlpool LGR3624JQ Gas Dryer
Dryer is cool not getting hot?
1. Close the dryer door and press the "Start" button for at least one second. Some dryer brands require the button to be pressed for several seconds. If the drum tumbles, you can eliminate the possibility of a problem with the electrical circuit that supplies the motor.
2. Check all the connections on the back of the dryer. Many dryers have two electrical circuits--one for the heat and one for the tumbling motor. If the motor works, but there is no heat, check to see if the larger plug is plugged into its receptacle. Your dryer may have two plugs--one small regular household plug and one larger 240-volt plug for the heat. Both must be plugged in for the dryer to work properly. The larger, three-pronged 240-volt plug will not fit in a normal household outlet; it needs a special dryer outlet. The plug cannot be cut down to fit.
3. Check the circuit breakers or fuse panel if the dryer runs but there is no heat.
Jan 14, 2011 | Maytag PYE2300AY Electric Dryer
Mi secadora enciende pero no calienta ,entiendo que no llega gas hasta el ingniter por que no huele a gas y el cilindro y su valvula funcionan bien.que puede estar sucediendo.? jr,gracias
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 15, 2010 | AEG T57800 Electric Dryer
Kenmore Dryer 65512 won't heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 14, 2010 | Kenmore 64742 Electric Dryer
Dryer noise and no motor action
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 03, 2010 | Maytag PYE2300AY Electric Dryer
Not heating
Hi
Things that could stop a electric dryer from heating:
  • house fuse or breaker ( needs two of them )
  • heating element, burnt wire
  • thermostat(s), thermal fuse ( not all models ),
  • motor heat switch, timer, selector switch,
  • burnt power cord/plug.
You can check these things using an ohmmeter/multimeter from here.
Things that could stop a gas dryer from heating:
  • glow bar igniter,
  • thermal fuse ( not all models ),
  • coils on the gas valve, gas valve, thermostats,
  • motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Kenmore 62802 Electric Dryer
My Kenmore 80 series dryer is shutting down
Please post the complete model number of the appliance.
Possible problems are -
1) Motor bearings are failing (lack of lubrication).
2) Idler roller is failing (lack of lubrication)
3) Blower bearings are failing (lack of lubrication)
Dec 29, 2008 | Kenmore 659 Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
