Question about Waring DMC201 Stand Mixer
Replace motor housing
Before I get aggressive, is there any secret to removing the shaft from the lower housing on the 210 class Waring 3-head mixer?
I can't believe someone hasn't answered this simple question!!!
Simply unscrew the agitator and slide the splash guard disc off.
The lower housing slides right off after you unfasten the three screw holding it to the upper housing.
Posted on Jul 23, 2008
How to remove top housing from Kenwood Mixer 210 series
A very well briefly written post, with lots of useful information.
Thanks for sharing.
KitchenAid Professional 600 Series
Jul 15, 2012 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid artisan ksm150 - Motor Head Locking Lever stuck in locked position
Get a copy of the Repair Part List of your model from Kitchenaid.com
Remove the Motor Housing (1). The Latch Lever (3) is connected to the Latch (10)
and held in place to the Lower Gearcase (5) by the Latch Bearing Screw (8). This
screw is visible from the outside and located near the Latch Lever.
Tighten this screw to fix your problem.
Aug 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
HOW DO YOU REMOVE THE PLANETARY ON A KITCHENAID MIXER MODEL KP26M1XGR3
Hi DAVE, Merry Christmas & Happy New Year! The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KP26M1, and select one of the first two files listed under Parts List (47) (The first file, KP26M1XAZ4.pdf (304.18 KB), is for a -4 series model and the second file, KP26M1XAZ5.pdf (724.41 KB) is for a -5 series with slightly different insides, so make sure you have the correct Parts List manual.) (For the purpose of this solution I will use the 5 Series Parts manual. Substitute accordingly if you have a 4 Series model.)
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts.
(1) Remove your KA Decorative Trim Band (Illus No. 3) by removing one (1) screw (Illus No. 22).
(2) Remove the four (4) head cover screws (Illus No 14) and lift of the mixer head cover (Gearcase Motor Housing top, Illus No. 1).
(3) Next, remove the two (2) screws (Illus. No. 14) securing your (Speed) Control Assembly (Ilus. No. 19) so you can move the Control Assembly out of the way. This will allow you better access to the Transmission Housing (Illus. No. 4).
(4) Remove the four (4) Transmission Housing screws (Illus. No. 14). Carefully lift the Transmission Housing off the base. The Transmission Cover Gasket (Illus. No. 6) may come off with the Hosuing or remain on the base. (Recommend reordering a new gasket if damaged)
(5) Remove all grease from inside the transmission cover and off all your gears. (This is the messy/fun part. While cleaning away the current grease, be sure to be keep and eye out for metal ‘filings’ that may be suspended in the grease.
(6) Remove the Worm Gear drive assembly (Illus. Nos. 16, 17, and 18) and set aside.
(7) Remove Retaining Clip (Illus. No. 7) from the Planetary shaft.
(8) Remove (lift up) the Bevel Gear (Illus. No. 8) from the Planetary shaft. This may require a little friendly persuasion, but it should eventually slide off the shaft exposing the Retaining Pin (Illus. No. 9).
(9) Remove the Retaining Pin. It should come out easily in either direction.
(10)You can remove the Worm Gear Follower (Illus. No. 10) but once the retaining pin is removed, you should be able to push the Planetary Assembly (Illus. No. 28) down through the Lower Center Bearing (Illus. No. 12). A few taps with a soft faced mallet may be required.
You now have access to the Planetary gear and Agitator Shaft Assembly (Illus. No. 34). Apply the same techniques to remove/replace any components from the Agitator shaft.
Assemble in reverse order above.
Continued in "Comments" - hslincoln
Dec 28, 2009 | KitchenAid K45SS Classic Stand Mixer
Where can I find a replacement motor for waring DMC20 drink mixer
take the model and serial number and contact your local catering equipment company . if there service department is open , then they can help . waring is a ok brand in the catering trade
May 14, 2009 | Waring DMC20 Hand Mixer
Taking the top off my kitchenaid mixer
Remove the back housing by removing one screw and liftingand pulling rearward.
Remove two screws holding the metalic edge trim. This uncovers the seam. Screws are on the back.
Remove four visible screws from the bottom of the head around and near the pillar.
Now gently using a screw driver, push the metallic ring on the mixing head down and off.
This uncovers five more screws about the mixing head. Remove them.
Using a very small screw driver or punch, puch the pin out of the mixing head shaft.
Remove the mixing head housing.
Lift up on the motor housing to remove it.
The motor/gear housing is the top protion of the mixer. Its loaded with grease so do this over a covered countertop or some place easy to clean. The grease won't run, but it can fall out in gobs.
Make sure all sealing surfaces are clean, especially the gasket around the gears. This will insure a good seal. No gear grease in your famous cookies!
Reinstall in reverse.
Feb 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Planetary Cover removal
Using flat screwdriver, remove upper main shaft cover screws (3 of them) to expose shaft nut. Using 3/4" wrench, remove nut and washer on top of main shaft. Using 9/16" wrench, remove double nuts and washers on both small shafts (the double bearing-retainer plate can stay screwed on). Using flat screwdriver, carefully pry stainless drip ring from lower housing (it's just press-fit). Using 3/4" wrench, remove acorn nut and locknut from bottom of main shaft (hold on to the housing, it's gonna drop down and it's HEAVY). Using flat screwdriver, remove cast iron cover hold-down screws (4). Place wood block over end of main shaft bottom to protect threads, and tap upward with a hammer. Don't go crazy with hammer, top housing could go flying. It may take several taps (it's on tight). Increase force slowly so as to minimize chance of damage. Prying out the two press caps from upper housing with a flat screwdriver will give you a place to stick your fingers to lift cover off once it's tapped loose.That'll get the top housing off. But planetary shaft isn't coming out without complete transmission dis-assembly. Better get a book, or better still, hire a pro. Just be careful with Hobart factory repairmen. I've had a VERY bad experience with a VERY highly-paid factory tech. You may have better luck than me, but I'd ask around at a few restaurants and search the 'net for an independant repairman. They tend to work harder for less money than factory guys, and take more pride in their work. Hope this helps!
Nov 26, 2008 | Hobart A200 Stand Mixer
Motor housing cap
I found out from a Waring rep that the motor housing includes the upper and lower units. The company I ordered the housing from didn't include the upper unit. Waring's solution was to return the lower housings and re-order the housing unit from a better company. I haven't heard from the company I ordered it from yet although I've sent them several e-mails.
My solution was simple. I cut the lower units so they'd fit as an upper unit to replace the upper unit
Jul 22, 2008 | Waring DMC201 Stand Mixer
Waring DMC201 Stand Mixer Logo
71 people viewed this question
Top Waring Food Mixers Experts
Oscar Netto
Oscar Netto
Marvin
Marvin
Are you a Waring Food Mixer Expert? Answer questions, earn points and help others
