Question about GE JGRP17 Gas Single Oven
How do i tell what glow plug to buy? Where is the ID number for the model GE single oven- I have no paperwork or manual from prior owner.
  • 725 Answers
Your oven has a serial plate on the inside of the door frame or at the bottom when you open the bottom part of the oven. If you will call us with the model number, we;llget the right part out to you asap!
972-859-0929. We love helping clients out with their appliance repair issues and you'll be cooking great meals right away! We look forward to hearing from you real soon.
Posted on Oct 05, 2009
Owner manual pdf
http://data.manualslib.com/pdf/6/584/58309-ge/jkp15.pdf?e5f6a2c77a078937daa77d391da45be4
Dec 09, 2013 | GE JKP15 Electric Single Oven
HOW DO I LIGHT OVEN PILOT?
Hi and welcome to FixYa, I am Kelly
Your model number was missing digits so I used this manual:
GRP17WEWWW
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981380002.PDF
and if your unit is older this one:
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=ShowPDF&FileName=49-8514.PDF
Automatic Ignition
The oven burner is lighted by electric ignition. To light the burner, press the pad for the desired electrical function and press the INCREASE or DECREASE pad until the desired temperature is displayed. The burner should ignite within 60 seconds. After the oven reaches the selected temperature, the oven burner cycles off completely, then on with a full flame to keep the oven temperature controlled.
GE contact data:
If you don't understand something or need more help, call:
GE Answer Center®
800.626.2000
24 hours a day, 7 days a week
Both the new and OLD units use a glow bar for lighting the burner. Most likely your Glow Bar has failed: GE PN: WB2X9154
The Glow Bar is item 316 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214914&diagram_id=20725728#d20725728
If you net search the WB ge part number you can save lots of money!!!!
http://www.amazon.com/WB2X9154-Gas-Range-Oven-Igniter/dp/B004H3XQPM
If the glow bar is glowing and you still do not get ignition respond here and we can go through troubleshooting.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | GE JGRP17 Gas Single Oven
Looking for an Owner's Manual for a GE Electric Single Wall Oven Model # JKP2OBOF3BB.
I do not see the JKP2OBOF3BB among the GE appliances. The manual for the JKP2OBFBB 27" Single Wall Oven is available here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-80475.PDF . Most GE appliance manuals can be found by searching here: http://www.geappliances.com/service_and_support/literature/ .
I hope this helps.
Mar 26, 2011 | Ovens
Oven and broiler isn't heating but the burners on top of stove work fine, what would this be?
It would likely be your igniter/glow plug.
There is also a limit switch or thermostat for that glow plug on some models which can go bad, but it is usually the igniter itself. Quite cheap to buy most of the time.
Mar 05, 2010 | Hotpoint SY21 Style Line Gas Single Oven
JRP 15 oven showed 350F and gave preheat beeps. Frozen lasagna "cooked" 45 mins and was still almost frozen. Oven was warm inside, not hot. Bottom element glowed orange when I increased the temp setting...
The oven was obviously not heated to 350 even though this was the setting. There is a very simple proceedure to calibrate the oven. It is different on different makes of ovens. Your owners manual will give you the detail of how to reset yours. If the manual is not available, click on the following link. Hope this is helpful.
http://www.applianceaid.com/temp-change.html
Oct 05, 2009 | GE JRP15 Electric Single Oven
Oven glow plug on but oven wont light , dosnt get hot , top burners work fine. broiler also dosnt work . oven about 13 yrs old
if ignitor glows and the burner does not fire within 30-60 seconds it is weak (not drawing 3.5 amps or higher) and should be replaced. Hope this helps,please rate my solution
Jun 26, 2009 | GE JGRP17 Gas Single Oven
Don't know how to light GE Glow-Bar oven
Perhaps the oven ignitor (glow bar) is defective. To test, check the voltage going to the ignitor when you turn on the oven to bake. If you have 110 volts testing with a voltage meter, replace the ignitor. If you do not have voltage, trougleshoot backwards to see where you have voltage in but not out.
If I can help further, I am here.
Eric Campion
Mar 04, 2009 | GE JGRP17 Gas Single Oven
Ge extra large self cleaning oven xl44 mode jgbp28ded1wh
Check to see if the ignitor glows in the oven. If it does not come on or comes on very dim, you have a bad ignitor. It is usually a bad ignitor. They are very simple to replace. Just unplug the oven first. Then take off the bottom of the oven floor inside the oven to access the ignitor. the ignitor has 2 wires going to a plug, just unplug the plug and remove the mounting screws. Take your ignitor to a local appliance store to get a replacement. There are 2 models of ignitors so bring the old one with you to make sure you get the right one. Good luck..
Oct 07, 2008 | GE JGRP20 Gas Single Oven
Gas stove
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Sep 04, 2008 | GE JGRP17 Gas Single Oven
Oven will not light
One of the Ignitor/orifice assy.,electrode is bad expecially the one your wife have to light.The circuitry is ok,but change that bad ignitor/orifice assy electrode.
Part number is Item # 833121: check it out @ www.repairclinic.com
Jul 04, 2008 | Frigidaire FGB24S5A Gas Single Oven
GE JGRP17 Gas Single Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
