Question about Maytag Dryers
Belt and drum turns but with a thumping sound.
Belt and drum turns but with a loud thumping sound. Speed seems fine, belt looks okay. Dryer is 15 years old......................could belt be stretched
    Sniper:
  • 68 Answers
Check the idler pulley, it could be broken. Also check the inner side of the belt for a chunk missing.
Posted on Oct 04, 2009
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
Maytag dryer (LDE5914ACE) loud slipping/thumping sound
yes, it's called a blower wheel... it is what blows the air into the dryer to blow out the humidity through the vent... it has a D fitting and as you use it, the D rounds out and the 'squirrel cage' stops spinning and begins to slip... if you continue to use the dryer without replacing this, you could burn up your dryer motor... it will just over heat....
Mar 19, 2010 | Maytag Dryers
Clothes dryer makes a ''thumping'' sound
One of your rollers has a flat spot in it or something stuck to it. Every time it rolls round to that spot the drum jumps over the little speed bump in the road. The wheel needs to be replaced.
Mar 11, 2010 | Whirlpool GEW9200L Electric Dryer
Dryer drum making thumping noise
My dryer just started making this noise. So I opened the back up to try to figure out what it might be, and when I opened it I saw something. It was part of the belt that drives the dryer. There are grooves vulcanized to the belt, and a small section of grooves or cogs I think is what they are called had come apart from the belt and what laying there on the floor of the dryer. But I ran it and timed the thumps in my head to get it to stop right on the "thump". Sure enough there was a small 1/2'' appx. of belt Cog missing, so the "thump" came from when the belt came around to the motor and the pulley hit a divit in the belt, "thump". So needless to say I need to replace the belt soon before it breaks completely. I figure that it looks like someone may benefit from knowing what the noise is. Now its off to find the proper belt and look up how to change those things...Good luck to those reading this.
jiujitsujd@aol.com
Jan 16, 2009 | LG DLG3788W Gas Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
GE Dryer DVL 223GB1WW
To access these dryers you open the door and look up at the 12 oclock position and their will either be 2 or 4 screws holding down the top. These must be removed and then you can get the top to come up(or off on newer models). Once you have the top up you can get to the screws which hold the front on (2). Then you simply remove the front and get it out of your way. On these dryers there is a friendly rear hatch to help you replace the idler. As far as the thump tha could be from anything. Once you get the dryer apart you should be able to locate and remedy the problem.
Dec 22, 2008 | GE DBVH512EFWW Dryer
Loud thumping sound
It's probably time for new drum support rollers. There are two rollers the drum rides on and their bearings can fail, which makes them noisy and also makes the drum wobbly while it turns. Replacing the rollers isn't difficult, and you can do it yourself if you feel comfortable working with hand tools and are patient.
Here's a good site with information on belt replacement and other repair tips, and a source for parts:
http://repair2000.com/wpoolbelt.htm
Nov 26, 2008 | Kenmore 63942 Dryer
ALWAYS UNPLUG ANY APPLIANCE AND TURN OFF THE GAS VAVE BEHIND THE DRIER BEFORE ATTEMTING TO MOVE IT. I HAVE REPAIRED GAS FIRED EQUIPMENT FOR YEARS ...ALWAYS MAKE SURE YOU LOCATE YOUR GAS METER IN THE HOUSE OR OUTSIDE AND HAVE A ADJUSTABLE WRENCH READY. I HAD A GAS VALVE BREAK-OFF IN MY HAND AND, A FLEX-LINE BREAK WHEN I MOVED A DRIER ... I WAS LUCKY I KNEW WHERE THE METER WAS. YOU CANT BE TOO SAFE !!! THE ONLY WAY TO CHECK A BELT IS TO REMOVE IT ... THERE IS A SEPERATE ADJUSTABLE PULLEY THAT ADJUST THE BELT TENSION (USUALLY LOCATED AT THE BOTTOM OF DRIER BELOW THE DRUM NEAR THE DRIVE MOTOR) YOU MAY OR MAY NOT HAVE TO LOOSEN THIS ADJUSTABLE PULLEY TO REMOVE THE BELT. FIND A CLEAR AREA WHERE THE BELT IS NOT ON THE SRUM AND PRESS ON THE BELT ... THERE SHOULD BE NO MORE THAN 1/2" OF "PLAY" ( MOVEMENT)IN THE BELT AFTER YOU REMOVE THE BELT ... TURN IT IN-SIDE OUT. AND SLOWLY ROTATE IT ... INSPECTING EVERY INCH FOR CRACKS AND EVSERSIVE SIDE WEAR. IF THERE ARE ANY CRACKS, VISABLE PLYS (LAYERS) OF THE BELT CAN BE SEEN, OR IT IS REAL SHINNY ON THE SIDES... THE BELT SHOULD BE REPLACED. WHILE THE BELT IS OFF ... USE YUR HAND AND SPIN THE DRUM TO CHECK FOR ANY WOBBLE.... THERE SHOULD BE NO WOBLING ... IF THERE IS IT MAY INDICATE BAD BEARINGS... HOPE THIS HELPED
Apr 28, 2007 | GE DVL223GB Gas Dryer
Dryers Logo
130 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
