Question about Husqvarna Garden
My skag rider mower does not want to start(turn over) when it has been running for awhile. when it cools after a few hours, it starts again. What is it/
  • 472 Answers
Sounds like you need to have the valves re set
Posted on Oct 15, 2009
John deere lx178
NEED VALVE JOB DONE MOWER IS OVER HEATING AND SHUTTING DOWN TO COOL OFF TO START AGAIN CHECK OIL LEVEL COULD BE LOW IF IS CHANGE OIL AND FILTER BUT GET VALVE JOB DONE BEFORE YOU SERIOULY DAMAGE IT VALVE JOB COST 100.00
Sep 01, 2014 | John Deere Garden
Have an old model riding lawn mower, the mower stated to smoke under the engine. Stop for a while to cool off and started mowing again and cutting belt broke, replaced it. Now the blades want cut, but when...
try removing the belt and try to spin the blades by hand. are they stiff to turn? if yes try to oil the bearing assys up under there and spin em again. if that seems to work out put the belt back on and mow away again! seen this on a neighbors rider a few times
Nov 06, 2017 | John Deere Garden
Hello, my craftsman 13.5hp ohv rider will not start. The left front tire deflated here 1 week ago, so I left the mower in the back yard for 2 nights, which happened to be very cold with frost. After fixing...
Remove battery and bring inside. Let it set for a few hours to warm up, it may be partially frozen. If you have a battery charger, after it has warmed up fully, charge it at a slow rate (1A) overnight. Put it back in the mower and try again. If still nothing, the battery may be ruined.
Oct 09, 2010 | Craftsman 1 Bin Grass Bagger
Craftsman rider wont stay running
Once having the same problem with the B&S engine, I had to replace the ignition coil. When it is in the process of failing, it acted as you describe.
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My skag rider does not want to turn over when it has been running for awhile but starts after a few hours.
sounds like either the starter is going bad or valves need to be adjusted
Oct 03, 2009 | Garden
Crafstman lawn rider 42" turn off after run for 2 minutes
sounds like your coil is getting hot and shutting down,, cool off and run for a while more,, coil is located next to the fly wheel,, just follow your spark plug wire and you find it,,,good luck
Aug 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mower stalls out after about an hour of run time
A few possibilities
1. If engine runs hotter than normal it can eventually heat up the carburetor to the point that there is a vapor lock. Blockage caused by gas bubble: a bubble of vaporized gasoline that blocks the normal flow of fuel. Problem goes away when things cool down. If that is the problem, you need to solve overheating problem. Since you have changed the oil, might be something blocking airflow to the flywheel which has the cooling blades on it. Or cooling blades are filled with debris. Make sure vent hole in gas cap is not blocked
2. Could be bad coil, or condenser causing the windings to act up when they are hot and have expanded they short out (kill engine) on their own casing. After they coil and shrink, they un-short themselves.
May 14, 2009 | Garden
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
