Question about Toshiba Satellite M35-S456 Notebook
COOLING PROBLEM PLUS A NOISEY FAN - Toshiba Satellite M35-S456 Notebook
I need software keygen challenge code for eset password toshiba m35-s456
Posted on Feb 22, 2010
My pioneer vsx-518 has a noisey cooling fan, is that normal?
Before replacing the fan, check for loose mounting hardware and cracked or damaged blades
Feb 09, 2013 | Pioneer VSX-518-K Receiver
D906 cooling fan
The fan may have worn bearings. Fit a new fan.
Feb 06, 2013 | DeLonghi Kitchen Ranges
My Verizon HD &DVR Set top box has a noisey fan running loud
The only thing I can suggest here is ask Verizon to replace and tell them why. If that is not an option move the box to a cooler location where the fan won't kick into high for cooling.
Jan 19, 2013 | Televison & Video
I have a caravell ice cream display chest freezer Model # 206-995 S/N 99500317 MFG # ast-30 It has a 3blade fan cooling the motor and fan is very noisey i lube it it s good for while then acts...
You can get that fan motor at most commercial refrigeration supply houses or try Graingers. It might be best to bring the old motor with you.
Jan 18, 2011 | Refrigerators
Fridge fan has frozen and has stopped. was noisey and stopped when door opened
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 12, 2010 | Samsung RS2534 Side by Side Refrigerator
NOISEY FAN
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 19, 2010 | Refrigerators
Cooling fan motor grinds and very noisey would like to replace cooling fan,where ca i obtain oem part for this mg250dfx
The fan will have a manufacturer's part and name on it.
Shop Digikey.com or Mouser.com for identical device.
Note that SOME amps have the fan throttled depending on temp and these fans get noisey when throttled down.
Not sure about your Marshall on. The usual fan failure is bearings get dry and coke the lubricant.
Feb 24, 2010 | Marshall Amplification Marshall MG250DFX...
Acer Aspire desktop AST135 cooling fan runs fast & slow - noisey
If the computer case, or Processor fan is noisy, it is due to the bearings are bad. The bearings are worn, and this allows the fan hub beneath the fan blades, to rub.
(If you gently rock the fan by lifting up on one side, and there is a perceptible amount of play, the bearings are bad)
Suggest you replace it.
For a case fan, just measure the dimensions of the fan's outside case.
Measure the Height and Length, plus the Width, (Thickness).
Look at the connector on the end of the fan's cable.
Most fan sizes are shown in Millimeters. (mm) If you are not familiar with the metric system, you can go online, and use a free Millimeters to Inches Converter.
Examples:
1) 80mm = 3.14960 inches. Slightly over 3- 1/8th inches
2) 92mm = 3.62204 inches. Slightly under 3- 5/8ths inches
3) 120mm = 4.72440 inches. Slightly under 4- 3/4ths inches
4) 130mm = 5.11811 inches. Slightly under 5- 1/8th inches
See if it is a 2 pin connector, 3 pin connector, or 4 pin connector, on the end of the fan's cable.
(Fans operate on DC electricity. Just like the rest of the computer. DC is a Positive connection, and a Negative connection.
For a connector with 2 pins, that is all that is hooked up. Just power to the fan.
For a connector with 3 pins, the third pin is for the computer, to show what RPM's the fan is spinning at. {Revolutions per Minute}
For a connector with 4 pins, the fourth pin is a sensor connection.
The computer will speed up, or slow down the fan, according to what RPM is needed)
For a Processor fan the connection should be matched also.
When looking for a replacement Processor fan, it is the processor socket that the processor sits in, that you should look for.
You didn't state the full Model Number, such as AST135-US3104, or AST135-US3303, (It's on the back of the computer next to the Windows Product Key)
The two above models have an AMD Sempron processor.
They use a Socket 754.
(AMD Sempron 3100+, and AMD Sempron 3300+.
The AMD Sempron 3000+ that operates at 1.8Ghz, could be a Palermo Core that uses a Socket 754, or the model that uses a Socket 939)
Need help in finding a replacement computer case fan, or Processor fan? State so in an additional comment.
Jan 17, 2010 | Acer (AST135-U-S3100) PC Desktop
Noisey cooling fan on graphics card.
Pretty much you are looking at replacing the entire card. Fans can be found but it is difficult and it is not worth the time generally to find them. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127368
Oct 15, 2009 | Dell Inspiron 530 PC Desktop
SONY KDF-50WE655 Cooling Fan
There are three fans: 1)Cooling fan(on the optical block)part# 1-787-057-11 2)Ballast fan part# 1-787-081-11 3)Upper optics fan part# 1-787-460-11 Also make sure you don't have a noisey iris motor in the optical block (verify by adjusting the iris settings in the menu and see if the noise level changes)
Sep 19, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Toshiba Satellite M35-S456 Notebook Logo
138 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
