Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Samsung LE32R74BDX 32 in......
Same problem DTV stuckon 1 channel....D.menu not responding..... ...... channel option (from DTV menu) greyed out.
when following given solution, channel option is greyed out
(D.menu not responding since 25thSept)
  • juliana_jame Oct 05, 2009
    this worked !!!!!(TOGETTO default screen/menu to reset&retune )Thanks very much!!!!
  • 6 Answers
Just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
Used suggested Solution to access DEFAULT SCREEN & RESET:
1. Enter STANDBY mode (Press Power on the Remote),
2. Press INFO, MENU, MUTE (Press in sequence,on the Remote),
3. Exit STANDBY mode (Press Power on the Remote),
....which brings up the DEFAULT SCREEN,
4. & then Select OPTION 12 to RESET , (Using DownArrow button)
..which Restarts in Plug&Play mode, then Select Country,
.... which then enters AUTO RETUNE/STORE.
...Seq Steps/Option I was looking for & Worked, THANKS!!!!
Posted on Oct 08, 2009
Did as suggested and yes got all channels back
Posted on Jan 21, 2012
Samsung lcd tv32 s 86 lost all freeview chanels. How do we get them back?
Enter the menu system and find the set up menu. Select the reset or retune option in digital mode.
It should rescan 21 - 68 and find the free view channels again.
Jan 03, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Can't get Digital TV (freeview)
Change the input to antenna.
If it says cable:
On your Samsung remote is a button that says antenna. You want it to say AIR. Air is an ATSC tuuner that allows you to receive over the air HD with a pair of rabbit ears.
If it says AIR:
If it says AIR and you still can't get the HD channels. In the menu it will say Channel. In that sub menu it will say autoprogram. Make sure you have an antenna connecte to AIR in the back of the set and autoprogram AIR only.
Any questions respond to this post and I will respond.
Jan 12, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Similar problem
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Oct 01, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LE32R7 will not retune since switchover
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Tuning option on menu is greyed out. cannot retune channels
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit the icon is not greyed out and tuning is possible.
Sep 30, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung LE32R7 in DTV mode stays on BBC1
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Freeview
go to menu settings, channel settings, set tv to CATV for cable, AIR for analog, or HD for high def.
Make sure you have the correct cables depending on your connection
Sep 16, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung tv LE32r74bdx only gives only one channel. Vere few menu are active.
Looks like the TV is in 'Shop' mode. To exit, with the TV switched on, hold the Vol down and Menu buttons on the side of the TV for 4 seconds - the screen will show 'Dynamic'. You should then have all of your functions back.
Jun 12, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
NO DTV CHANNELS
There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
Feb 16, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LE32R74BDX ...DTV problems
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Oct 23, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
1,216 people viewed this question
Jerry Greenberg
Jerry Greenberg
